Caliper spring plate bolts?
Hi,
Does anyone know of a source for the caliper spring plate bolts for the 993? I know they are different to the 964's but I assume that brembo makes the parts for both and I'm not having much luck on the 993 board.
Cheers.
Cheers.
a964man, excellent I do actually need all 16 though, all the plates are off the callipers. I'm actually going to paint them like you did. If you can spare 16 bolts, I'm in Cardiff this weekend to see my family, so I could swing by!
Technical Guru
![](https://members.rennlist.com/jandreas/SpringPlateBolt.jpg)
no problem I have 16 spare, free to a good home PM me for details, your welcome to collect, by the way i ended up having to cut them down by about 4mm
worked fine, are you happy to do the same?
Cheers Andrew
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Cheers Andrew
You can get stainless M6x1 button head Allen bolts from the major hardware suppliers. I'd go with Bel Metric, I believe that's where I got mine.
I don't know the length, but here they are: https://www.belmetric.com/6mm-c-563_...4r4cq5flnmrgi6
Technical Guru
At this point, if you are replacing the bolts you might as well replace the spring plates themselves. They permanently deform outwards and prevent the brake pad from moving. Eventually, you'll get to the point where there is nothing remaining on the edge of the brake pad to file down to prevent this. The kit price is about $40USD/each.
They get bent from corrosion building behind them pushing them toward the pad while the screws are still secured. It's very easy to tell if they sit flat against the caliper when both surfaces are clean. If they do, there is no reason to replace them. Media blast them (glass or ice preferably) and throw them back on.
