225/45/17 tyres rubbing at the front !?!?
Just put 225/45/17 tyres up front with 5MM spacers
The offset of the wheels is 52, which is correct
But the tyres are rubbing the outside part...
I will take the spacers out, but I am afraid the tyres will start rubbing on the inside part
I am waiting to get 10MM steering stops
Should I better go with 205/50/17 tyres ?
Both...
Bumps: surely it will hit the outside
Spirited driving: less, but also
Or should I go with 215/45/17 tyres ?
Don't go to 215/45 in the fronts unless you are also planning on reducing the overall diameter on the rears also. Since you are running a C4, I would try to stay with 205/50 or 225/45 on the fronts and 255/40 for the rears. The rolling diameter matching is important on a 4WD car.
If I recall, stock 17's are ET55 for F/R and not ET52. Are you running 17x7 ET52 in the fronts? If so, you are extending the wheel out by ~8mm over ET55, when you use the 5mm spacer. If you are running 17x7.5 ET52 with 5mm spacer, you are extending your wheel by ~14mm over 17x7 ET55 factory wheel. Perhaps that is the cause of the rubbing, along with the added width of the tread.
Hope I am making sense, because sometimes I can't even understand what I saying
Don't know about the camber...
But yes, 7.5" width wheels, ET52 with 5MM spacers
Maybe taking away the spacers will solve the problem, but I will have to get the 10MM steering stops instead, correct ?
Maybe it is time for an alignment and take the opportunity to possibly enhance your handling. Since you are running 7.5 ET52, I would take away the spacer if you are rubbing on the outside. 5mm might not seem like much, but it helps. As for the steering stop, I don't have any experience in that since my 964 is a widebody and using 965 suspension.
It seems the best is going for 205/50/17 tyres up front, right ?
Which tire brand? One would think they are all the same size but they are not.
I run 225/45/17 front and 255/40/17 rear on Cup II wheels, ET55 for both. Other then the aforementioned huge *** turning radius...no problems or rubbing anywhere with a lowered suspension.
I have 205s on the front with lowered suspension and a get rubbing on the inside on full lock. Steering stops should fix but then as mentioned you'd get a huge turning circle!
Originally Posted by deoxford
Speaking of tires, I just got a set of 225/40/17 and 275/40/17s
will there be any issues there?
