Another Oil Leak thread
Happy New Year, I have owned my ’90 964 C2 coupe for two year and it has been leak free. This summer it started slightly leaking in the area of the oil tank but I expect that to be one of the many pipe connections so I put off working on it till I put the car up for the winter. Salt on the road = no driving.
Now I am into the winter maintenance work and I find an unexpected task, oil leaking from the oil line that goes from the filter, across the back of the engine and under the heat exchanger to the block. The leak is at the block connection. Anyone been here?
Questions:
1) The driver side heat exchanger keeps me from putting wrenches on this connection. I assume I get to pull the heat exchanger/exhaust header as one piece. Any tricks I should know? The exhaust port nuts are rusted and I am applying penetrating oil. I see the crossover from the right side comes into it also and those nuts look the worst but they are bolts and will be easily replaced. Just looking for experiences and things to watch out for.
2) is there an o-ring in the oil pipe connection?
Thanks in advance, Vince
Questions:
How much does it leak ?
Its a case not a block .
"The driver side heat exchanger keeps me from putting wrenches on this connection."
This is an international forum with people who drive on the other side so ....
The oil line connection to the case is a common leak point. You just need to tighten the connection, but you will need to drop the dirver's side exchanger. Pretty simple task as long as you can get all the bolts loose. The crossover pipe and the cat need to be disconnected. If the oil is leaking all along the hose, you may need to replace the hose or it may be the crimp connection under the heat wrap. You can take it to a hydraulic shop and they can probably make a hose cheaper than you can buy. Or they may be able to recrimp.
Yes it is the right side case. I have the cat off for the valves so as long as I can loosen the nuts, no problem. I have all winter to wait for the penetrating oil.... The oil appears to originate from the case connection and blow back. "The hose" is a hardpipe but, now that you mention it, there is also a bit of oil back by the heat wrap. I'll pull the whole pipe and take a look.
Thanks for the replies,
vince
vince
Now you have some of the clutter off, if you are in no hurry why not clean everything off and wait and see where the leak develops. Without the air swirling around from driving you won't get the oil blown everywhere. Would also be worth checking the bottom of your barrels too whilst you're in there as sometimes this leaks down onto the oil pipe and can look like the oil pipe at first diagnosis.
Ian.
Ian.
Ian.
Ian.
jg
Ian.
Ian.
vince
Technical Guru
Originally Posted by greenjt
Hey Ian, what is the fix if it does end up being the bottom of the barrels? I have the same constant drip on the fitting in question. Leaves me a drip after each drive. Been meaning to get to it and have finally resolved to do it this month.
jg
jg
Regarding the oil pipe fitting isn't there two possible sources for a weep here? 1/ Where the pipe screws on to the fitting and 2/ where the fitting screws into the crankcase ... been a while so memory might not be 100% on this.
I have a similar issue witht the short pipe connection on the rhs. I did a rebuild and now this has started to leak several months later. I have ordered a new pipe from Porsche. I also ordered new gaskets between exhaust and heads and between exhaust halves.
Can anyone vouch for the quality of the hose from EBS? I know some have posted their problems with aftermarket hoses from filter to tank.
Technical Guru
So now I have tried to start pulling the exhaust manifold and the nuts are a challenge. Not to loosen, but to reach. My socket does not fit in the two holes in the heat exchanger and the other four nuts are a !@#$%^ to reach. What wrenches do people use for the open nuts? And I guess I need to buy a thin wall 13mm socket.
