Another Oil Leak thread
I just ordered that line for my car also. $265 from a Porsche dealer. Most dealers wanted $400.
I ordered the ones from thermostat to cooler, also. They are leaking now.
I used real nice swivels to do those pesky nuts.
Technical Guru
Originally Posted by Vince pavlicek
What wrenches do people use for the open nuts? And I guess I need to buy a thin wall 13mm socket.
I'll accept "just fight them off with whatever wrench you can get in there" but I hate doing that on torqued nuts to avoid rounding or snaping them off
Originally Posted by Indycam
How much does it leak ?
Thanks for the swivel socket advice. A quick trip to Sears Hardware and the nuts came off cleanly.
Next I'll pull the oil tank looking for that problem and make a list of parts to order for what I find and include the header gaskets and nuts.
Everybody needs a hobby, and I smile all the time when I'm driving mine.
One of these days I'll take a new signature picture.
vince
The line that you are replacing is a common one to leak, however the pipe is often made incorrectly which will cause a leak at the fitting on the block. I have seen this fault on many occasions and have had to remedy new pipes before fitting so please be aware of a possible issue.
The problem is that the clamp nut on the pipe is sometimes manufactured too deep, so that it bottoms out on the hex of the nipple (the double-threaded part in the block) before the conical seal area of the pipe is fully compressed into the taper of the nipple. Once the pipe is trial fitted, nip up the nut onto the nipple and test for any movement or rotation of the pipe, if there is any movement whatsoever the solution is to remove the pipe and shorten the clamp nut by filing material from the face of the nut until there is slight clearance when the nut is fully tight. This is pretty obvious if you have the parts in front of you.
Good luck with the rest of the work.
Originally Posted by greenjt
Coin - I was once told that teflon tape might be another solution. Stupid or valid idea? Thnx.
Technical Guru
Jason - Why am i not surprised you have a picture of that... ;-). Thanks for the 411.
So since i get a drip after each drive from this fitting, what would you do?
1. try snugging down the nut over the compression to hopefully stop the leak; or
2. Since i would have the heat exchanger off anyway, replace the fitting that connects the oil pipe to the case.
#2 would reduce the cance of needing to get back in there, but i think would also require draining the oil. Thoughts?
Also, could the leak be coming from the other side - junction between the fitting and the case?
mine actually leaked from the fitting in the case. It was about a 1/16th of a turn loose. Just needed snugging up. You will have to loosen the hose fitting before snugging up the case fitting.
