Hard Brake lines
What lines are you replacing? The short hard lines all have an MSRP between $11-$12USD so they are available for ~$5-6USD. This is the same price as buying raw pipe from Autozone but the porsche lines are also higher quality (copper-nickel alloy called Cunifer) and include a thick anti-corrosion coating. You also save $10-20 from not having to buy a pipe-bending tool. I'll admit it is a fun tool to play around with.
965-355-581-01 (1) $11.50 Front (left)
965-355-582-01 (1) $11.50 Front (right)
965-355-191-00 (2) $12.36 Rear
Jason, you saved me a big headache I was installing lowering springs this weekend and was on the last wheel (RT front) and when I tried to remove the brake line the line would only twist so I just ended up cutting the line. I searched to find the part # for the brake line but had no luck until I saw your post with the picture and part #. Thanks again
