8 & 9.5 CUP 1
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by skruggs964
The question I need to ask....will they fit on a narrow body '91 964 without spacers??
Front rims 17 x 8 with 52 offset
Rear Rims 17 x 9.5 with 47 offset
Thanks!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks!
Additional info is here:
https://rennlist.com/forums/964-forum/314645-964-wheel-questions.html
Originally Posted by Cupcar#12
the only 47 offset out there from porsche in 17" is a winter 996 wheel.
the cup 1's 17" were only 68mm offset (sorry late again to the party) the 18" speedlines were 47" (need to verify the MS parts list again for 92/93)
but anywhoo.... Motorsports only called out these 2 wheels for the 964 cup cars. No 47mm in 17" for the 964 or the 993
Originally Posted by ltc
OK, why is it I'm the only person who can't seem to locate these
I'd be happy with just 2 sets.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
OK, I dug out my parts catalog for the Cup cars. Here is the scoop.
The 3 piece Speedline wheels used for the 92-93 Cup season:
965.362.136.00= 8X !8 offset 52 mm front wheel (same part number as 3.6 Turbo front wheel)
965.362.138.05= 9.5 X 18 offset 47 mm rear wheel (not used on any other car I know of)
The one piece cast Speedline wheel used before the '92 Cup season:
965.362.126.00= 8 X 17 offset 52 front wheel (same as rear wheel RSA or 17" wheel option 964)
965.362.128.05= 9.5 X 17 offser 68 mm rear wheel (also used as upgrade option on rear of 3.3 Turbo and 928, needs 19 mm spacer and long studs)
zOf964Cup (01-01-2021)
Hi,
I have those 9,5" Rims on my 964RS.
Look at my Avatar and the added pics.
I use the 21mm spacers. That´s important, ´cause the tires must have enough
space to the axle control arms.
It´s possible to use 25mm spacers.
Cheers
Sparxx
Cheers
Sparxx
