964 Forum 1989-1994
Putting the heavy 964 on a diet?
Old 03-21-2012, 09:37 AM
  #31
911Jetta
911Jetta's Avatar
As in what not to do...?
I looked at some of those threads...rolled fender lip, massaged flair, flattened oil line, rubbing..., wheels sticking out.
Sorry you had to go through all that hassle!
Thanks for the heads up.
Old 03-21-2012, 09:49 AM
  #32
Goughary
Goughary's Avatar
what Offset in the OZ wheels would work without having to modify things?
Old 03-21-2012, 05:15 PM
  #33
kos11-12
kos11-12's Avatar
Hi, few guys here have fited the OZ Allegeritas,
Personally, and as I think less is better I will go for 8 front & 9 rear with 225 and 255 or 265, witch is a good OD for the C4 , I run 1,5 camber they will fit well, maybe with a 5 to 7 mm spacer to bring them out a bit ....
At the moment my Speedlines are 8 1/12 ET 52 & 10 ET 56 with 7 mm spacer at e back and it's perfect, RS geo slitly lower at the front...
Old 03-21-2012, 05:49 PM
  #34
Goughary
Goughary's Avatar
ok - so maybe we should start a 'Show us your OZ Allegeritas and your offset" thread?
that would be a good one that I'd like to see. 17" vs 18", offests, etc...
Who has the nicest setup?
Old 03-21-2012, 06:23 PM
  #35
sml
sml's Avatar
just go for the tirerack recommendations .. EDIT: the 10ET40 seems to work for some without any mods.
the front recommendation is 8ET50. works fine but i had my car quite low at approx RS height, so i rolled the lip just in case.
cannot remember the rear but just do the tirerack car fitment search.
you can fit 10ET40 without mods if you are happy with max neg camber and potentially a slightly higher ride height.
Old 03-21-2012, 06:29 PM
  #36
sml
sml's Avatar
Originally Posted by 911Jetta
As in what not to do...? I looked at some of those threads...rolled fender lip, massaged flair, flattened oil line, rubbing
i thought the 10ET40 were perfect.
some guys have fitted 10ET40 with no issues but a slightly higher ride height. you can search and find his pics.
i had my car just below RS height and required ..
1. -2 deg neg camber
1. a slight lip roll and fender flare of about 3-5mm.
not too hard .... but yes, if my read thread, i detailed the learning curve to help others understand the issues and seek advice. if you want 10ET40 at a low ride height, then just want it to fit follow the two simple steps above.
would definately buy 10ET40 again. perfect.
have you lowered your car yet?
Old 03-21-2012, 06:31 PM
  #37
sml
sml's Avatar
10ET56 with 7mm spacer = 10ET49
so 9mm further inwards compared to my 10ET40.
around 10ET44-47 is generally the perfect fit for no mods.
what is your clearance to the inside oil line with 10ET49?
Old 03-21-2012, 06:36 PM
  #38
sml
sml's Avatar
this is 10ET40 with no lip roll or fender flare .... you can find his original thread on the forum here ....
Old 03-21-2012, 06:38 PM
  #39
sml
sml's Avatar
i think this one is 10ET40 no mods .... but message the guy to confirm ... not 100% certain ..
https://rennlist.com/forums/9175799-post88.html
Old 03-21-2012, 06:48 PM
  #40
sml
sml's Avatar
This was final summary from the thread .. 10ET40 .. probably didnt need quite so much lip roll / flare in the end as you can see here ...
Height = 228mm rear (RS+5mm)
Camber = -2 degrees
Springs = 650lbs
Tyre = 265/35
Fender Lip rolling = 3mm
Fender Flare rolling = 4mm
Old 03-21-2012, 09:15 PM
  #41
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Yeah. To make it easy on myself just put 18" rims that were 8ET50 and 10ET65 (with a 21 mm spacer so effective ET44) with RS ride height (-3.0/-3.2 degrees camber)and 500/780 springs and they just fit but hey, what do I know, I am no wheel offset expert. Maybe I just got lucky.
Marc
Old 03-21-2012, 09:30 PM
  #42
sml
sml's Avatar
max neg camber on my stock car is -2 deg.
questions were about OZ alleggerita (10ET44 not available) so there are limited offsets to choose from and spacers are illegal in certain countries.
Old 03-23-2012, 04:57 AM
  #43
kos11-12
kos11-12's Avatar
SML your wheels looks good, the black colour is a perfect match, I would like for the graphite as my car is polar silver,inside clearance is just under 10 mm
Quick Reply: Putting the heavy 964 on a diet?
