964 Forum 1989-1994
Need advice on jacking up a 964
Old 10-31-2006, 03:38 PM
amfp
amfp's Avatar
Andreas,
Very clever. Have a question, not sure what is meant:
"I go to the rear again and raise the stands another hole to get the car level".
To raise the rear stands do you jack the car up in the rear again ? TIA.
Old 10-31-2006, 11:45 PM
AOW162435
Seared
AOW162435's Avatar
mo,
Regardless of how much I adjust the rear, it's only done to bring it up the same height as the front. I'd rather not raise the rear as high as possible during the first placing of the jack stands. But yes, I simply lift under the case again until I can raise the rear stands to where I want them.
Andreas
Old 11-21-2006, 05:01 PM
deep_uv
RIP
deep_uv's Avatar
I got my car jacked up yesterday. I put it on the stands in front by jacking at the rear jack points and then used the engine to jack up the rear. The AC stands make it a breeze and are really solid. You'd have to try really hard to upset it. Here's some pics.
Steve
Old 11-21-2006, 05:23 PM
TR6
TR6's Avatar
Hey Steve, where did you buy your jackstands? I need to get a new set since mine are all axle-type jackstands. -thanks!
Old 11-21-2006, 06:08 PM
deep_uv
RIP
deep_uv's Avatar
They're AC hydraulics brand and the only place I've found to buy them is Pelican for $179 a pair. I think you might can buy them direct from AC Hydraulics but it's the same price either way. Here's a link to where they're listed on Pelican. No affiliation, blah, blah, blah. AC Hydraulics Jack Stands
Steve
Old 11-21-2006, 06:11 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Greg,
The jack stands are available from Pelican Parts (no affiliation). I bought one of their floor jacks and love it. I've been thinking of getting these jack stands myself.
http://www.pelicanparts.com/catalog/...ACHyd1_pg5.htm
Old 11-21-2006, 06:21 PM
AOW162435
Seared
AOW162435's Avatar
I purchased my stands through The Ultimate Garage. I was able to pick them up in person to save on shipping. Good stuff.
Andreas
Old 11-28-2014, 01:09 PM
VR6-er
VR6-er's Avatar
Just in case you haven't seen these. You could use them to raise the car and then still use conventional jack stands if you want the wheels off.
Old 11-29-2014, 04:24 PM
hepkat63
hepkat63's Avatar
Originally Posted by deep_uv
Greg, From this and other threads you've posted in recently, sounds like you and I are both going to be putting our cars on stands for the first time. I'm going to use the traditional get the front up first and then use the engine to get the rear up. I'll be doing a (first time for me) brake job and brake flush and bleed, installing a cup bypass, oil change, transmission oil change, engine cleanup, oil leak inspection, etc.... We'll have to stay in touch. I'm using 4 of the AC hydraulic flat top stands in the attached picture. They are kinda pricey ($179/pr), but I like you don't want to take chances under the car and these seem like they'd be pretty safe and stable compared to the traditional axle stands.
Steve
+1 on these stands - they are brilliant (no affiliation). Yes, 964 are a pain to jack up. Certainly, if you are going to work on your own car a lot - invest in a scissor lift... or build a pit
Old 11-29-2014, 04:31 PM
hepkat63
hepkat63's Avatar
Great Idea for lifting a car - YouTube
where do you buy those from? Website has no details who sells them?
Old 11-30-2014, 01:56 PM
-nick
-nick's Avatar
Always thought that these were pretty neat. Though pricey, and you only get one height out of them.
http://www.jackpointjackstands.com/
Related: You can sandwich a hockey puck between the rear engine tray and the center rib of the engine. Then center your jack beneath the hockey puck. With a rubber pad on the jack saddle, you can safely lift the entire rear with the engine tray in place.
So you end up with: jack>pad>engine tray>hockey puck>engine.
Old 11-30-2014, 04:09 PM
Gregt909
Gregt909's Avatar
If you don't mind spending $2k I like the ez lift. I didn't want to install a permanent lift in my garage so this was a nice alternative.
Old 11-30-2014, 06:12 PM
LPMM
LPMM's Avatar
Website http://myliftstand.com - email william@myliftstand.com (no affiliation)
I contacted Bill and they are $265/pair + shipping, truthfully I was hoping for a little less. He mentioned that he sends you a Paypal invoice and ships the stands as soon as payment is received. Here is the additional info Bill forwarded:
∙ Lift Stands are made of 12ga. steel and have a black durable powder coat finish.
∙ A lift stand dimensions are 11”wd. x 18”lg. x 8"high. The extended height is 13.5 inches.
∙ The inside section of the top tire pan is 11"x11"x 1.5" deep.
∙ The locking pins are spring loaded, and made with .375 inch stainless steel.
∙ One stand weighs 35 lbs. with a maximum load rating of 2000 lbs.
∙ Four stands will support an 8,000 lbs. vehicle.
∙ Any floor jack that is less than 12 inches wide can be used.
∙ Warranty is 1 year on product to be free from physical defects in material and workmanship.
Old 11-30-2014, 06:25 PM
Vegas993
Vegas993's Avatar
Esco Jackstands
Old 12-02-2014, 11:49 AM
deadendd9009
deadendd9009's Avatar
Im sorry to ask this question, but is it safe to raise the rear of the car from the engine using stock OEM motor mounts? I keep reading posts that contradict each other.
I need a definitive answer before I ruin my mounts, thanks for your help!
Quick Reply: Need advice on jacking up a 964
