Fabspeed Cup Style Airbox warning
Technical Guru
The Fabspeed "cup" style airbox cover is missing ribs that would normally stiffen the cover similar to the factory piece possibly because of its manufacturing method, vacuum forming? Without the ribs and because of the thickness of the plastic the two clamps at the very top and bottom will cause the cover to warp and the air-filter element will not seat properly within the airbox. The real problem is that you will only notice this if you happen to remove your engine or live on a dirt road and just happen to clean your intake manifold from an oil overfill. So if anyone here has a Fabspeed "cup" style airbox I would suggest sticking their hands in back of the intake manifold and checking that the filter is seated properly. FYI, the engine vacuum will not push the filter element flush...
![](https://members.rennlist.com/jandreas/964-Airbox-Fabspeed.jpg)
![](https://members.rennlist.com/jandreas/964-Airbox-Fab-CloseUp.jpg)
![](https://members.rennlist.com/jandreas/964-AirBox-BackSide.jpg)
1 Post
I have one of these and yes, you have to take extra care when you fit the cover to ensure that it seals all the way around. It will seal, but you do need to double check to make sure it is installed properly. I run my fingers all the way round to make sure there are no gaps.
Technical Guru
Jaon
Sorry, but your last post is a bit ambiguous! It could be read as
1. after initial fitting it was OK and then subsequently it opened up
or
2. You thought you had fitted properly but a better inspection found that you hadn't
Which leads to the question of whether, with care, this product can be used or not.
or
Jason ,
Why not cut the top off a standard lid and use a regular paper/oil filter ?The lid frame will seal the filter.
Thats if you really want this set up. We wont go there again !!
All the best
Geoff
All the best
Geoff
Technical Guru
Originally Posted by bgiere
...And how much does that little piece of carbon fiber cost?
Originally Posted by JasonAndreas
I've always used the stock factory air filter and after I noticed this problem decided to just stick with the factory cover. If I see a factory cover for sale on eBay I will buy it and dremel tool a cup cover.
Technical Guru
Why not? Moisture?
Why not? Moisture?
I am not saying it's a No No but I'm just extra precautious.
