Front differential seals
My front differential appears to be making quite a mess with fluid all over the plastic undertray. (discovered while doing the fuel pump change).
Searching the forum didn't reveal a whole lot of insight into this problem, so maybe this is an uncommon occurence?
The fluid appears to be coming from the output shafts, however the PET doesn't show any seals on the shafts. All it shows is an "adjusting ring" (950 332 268 00) and a "taper roller bearing" (999 059 064 00). Do either of these parts perform a sealing function? The PET does list a shaft seal (999 113 347 40) but it appears in the diagram to be inside the diffferntial housing?
I did find one person (993 forum) that replaced the input shaft seal. Is it possible for fluid to leak out there, drip down onto the output shafts and get flung everywhere?
frank
frank
Frank,
I am going to replace my front diff seals over the winter.
P/N 999 113 347 40 ( unless Jason knows better ! )
Gradually worsening leak is pretty normal when they give up. Disconnect the axles, take the centre bolt out of the flanges. Pull the flanges and then seals.
I am going to take a look at the flanges at the seal contact area and decide if anything needs to be done.
Pushing the new seals in with limited ! access can be fun. Normal PIA 911 job.
All the best
Geoff
All the best
Geoff
My front diff has been leaking since I bought the car. I've had all the seals changed, and now its not leaking, but there is a very slight weep from it. Apparently its fairly common for the front diff to weep a bit.
DavidP
DavidP
I'm pretty sure it's not PS fluid - my PS reservoir is still full after changing the fluid about 18 months back.
however, when I (finally) got the fill plug out of the front diff I stuck my finger in the hole to feel the level (I'm part dutch, so sticking my finger in a - oh never mind) I could only feel the wetness of the housing inside
I topped up the fluid (took about 200 ml by the eyeball judgement) and noticed new wetness under the car so it's leaking pretty bad I figure. Haven't put the car up again to check the level yet but I'm sure it's low again.
Thanks for the part number Geoff - I'll see if I can get those through the local shop.
Does anyone have or know of a DIY thread on these seals front and back? I'm going to be doing these seals in the coming days and don't want to open it up and find I can't do the job.
IHI KING!
Sorry haven't done it myself. My mechanic did it about 7 years ago when I didn't have time to do it myself. I remember, he said that it he ended up dropping the whole front suspension to gain access.
Please keep us posted on what you learn.
Rob , I'll write this up in the suspension madness thread, but honestly this job is so easy, we are all idiots for not doing it as matter of course when we have done cv boots. If the axles are out anyway, it's an extra small job to change a seal that has to be toast after 25 years. Wait till you see the seal and how it works. You'll be amazed it lasts five years.
Anyway. If you look in the shop manual, look at the photo of the front diff. The entire job is explained in that photo. Couldn't be easier. Except it's a pita to get the old seal out. But you take out the 17mm bolt, slide out the flange. Pry out the seal, grease up the new seal, press that in. Push the flange back in, and torque the bolt to 44nm. Use a long m8 bolt through the holes on the flange to stop the flange from turning when you torque the 17mm bolt. Done.
Oh, dump the tranny or diff fluid first...
Refill fluid when done. And done. Easy job.
Except for when i screw stuff up...lol. One of the seals went in wrong and I had to peal it out and ruined it. So we ordered another and when that comes I'll finish the other side of the rear.
