Guage Upgrade (Pics)
#32
#33
Originally Posted by kristianw
Hey Dave,
Would you mind posting some pics of how yours look? I'm curious to see how they are compared to mine.
#34
I just realised, it's probably dark enough in the garage to work anyway - so here they are. You'll notice the '0' on 40 - and the tacho looks like it needs another light at the top. I did make sure each LED was working while the clocks were out but I'm tempted to take the tacho out at some point to make sure I didn't make a mistake. Oil temp / pressure gauge looks fine even though one bulb doesn't work for some reason!
#35
Dave, mine just arrived and all are fitted except rev counter. look good I am happy but I have a question.
how do you take a steering wheel off
i have nver done it before. Looking at other threads they say you can just rotate teh rev counter but I tried that.
To me it looks as thought the plastic shroud behind the steering wheel is what is holding the rev counter in. do you need to remove that also?
Cheers
Phil
ps my speedo looks exactly the same as yours with a couple of bright spots
Cheers
Phil
#37
Taking my steering wheel off is easy - it's non airbag. Just pop the cover off, remove the big nut, pull the steering wheel off. If you've got an airbag then it might be more complicated.
And yes - I removed the plastic cover over the switch assembly - just a few screws. Don't think you can get to them all without taking the steering wheel off though.
