964 Forum 1989-1994
Different gears for odometer + tripmeter ?
Old Sep 30, 2006 | 10:47 AM
tonyc's Avatar
tonyc
Default Different gears for odometer + tripmeter ?
I wanted to check my mpg on friday so pressed the reset button and since then neither the odometer or tripmeter have worked. I gather this is a common problem with the gears breaking. I am going to attempt this myself and will order the gears. Two questions:
1) Are there different gears for each or will one set repair them both?
2) Could it be anything else I should check before I start on removing the whole unit from the dash.
Tony 90C2
Old Sep 30, 2006 | 11:24 AM
DaveK's Avatar
DaveK
A stupid question - but you have tried pressing the reset button again? Mine has done this once or twice (I always reset the trip when I fill up with fuel) but pressing the button a few more times usually frees it up.
Old Sep 30, 2006 | 11:35 AM
tonyc's Avatar
tonyc
I have Dave, a number of times. Will do it a few more before I attempt this though. Maybe one last one with a bit more pressure.
Old Sep 30, 2006 | 03:26 PM
BS911's Avatar
BS911
Hey Tony. The one gear turns both the odometer and tripmeter. I would say it is a safe bet that there is nothing else to check as long as your speedometer itself is working.
Old Sep 30, 2006 | 03:40 PM
dfinnegan's Avatar
dfinnegan
I, too, had mine lock up after hitting the trip reset. I fiddled with it quite a bit and it freed up.
Do let us know how you get on as I expect I'll be faced with this fix before long.
Cheers,
Dave
Old Oct 1, 2006 | 10:49 PM
Richard Curtis's Avatar
Richard Curtis
If it's any consolation, replacing the odometer gear is a very simple DIY, just be careful. DIY instructions should be posted somewhere (do a search on this list). The gear is available for about $25 IIRC. Since I did mine, i've since read somewhere (this list probably) that you can replace the gear without disassembling the speedometer, especially having to remove the speedo needle. When I replaced my needle, i didn't get it in the exact right position and wound up with a speedo reading 3 mph off... indicated 80 mph is actually 83 mph as measured by my GPS unit.
Old Oct 2, 2006 | 04:02 AM
CraigyB's Avatar
CraigyB
I would reccomend looking for a VDO repair outfit in your part of the world. This isn't a simple repair and there is a lot of scope to break things. For a start off you need to remove the bezel around the glass, and if you don't take care, it will be difficult to refit, and will be obvious to a potential buyer should you sell it that the gauge has been tampered with.
I would say this is doable though, but when I had similar problems, I just got it repaired and cost me £70. Not worth attempting myself for that kind of money.
Old Oct 9, 2006 | 01:12 AM
tonyc's Avatar
tonyc
I am still contemplating taking this job on myself. Before I order the parts online, how close is the speedo to that of the 993's? I see there are detailed instructions on the 993 p-car site and a friend with a 993 has just done his succesfully this weekend without too much problem.
I offered moral support with a beer in hand !
Tony 90C2
