heater bypass: go or no?
so as most topics in this area, how many have done the heater bypass to the CF tube and eliminated the 15lb fan/anchor?
Likes and dislikes?
Issues with change?
most appreciated!
Likes and dislikes?
Issues with change?
most appreciated!
My $0.02 based on having done it:
If you drive the car on the street or in the rain, I would not recommend it. The defrost is really crappy without the fan and 15 lbs difference is not worth worrying about for anything other than a highly competative track only car.
I second that... I have it on my race car, but would never do that modification on a street car - I don't really see the point since it impacts your climate control significantly!
15lbs? Just use 3 less gallons of gas. Or take a lighter passenger for a ride
Technical Guru
Technical Specialist
Lifetime Member
Lifetime Member
Since I installed the cup pipe and posted on how to package the electronics to 'fool' the CCU that the motor was still there, I have a few thoughts.....first, if you go my route, it only works on later 964's. Porsche changed the CCU in, I believe 1991, so '92 and later cars can do the mod I did. In terms of effectiveness, it works fine. I have air when I need air, regardless of temperature dialed in. As pointed out, you do lose the fan automatically cooling the heat exchangers when shut down hot, however, when I had the entire stock setup, I never heard the fan cooling the heat exchangers.
As mentioned, it's only 4.x or maybe 5 lbs of weight. The biggest benefit is better access to the left side (as you look at it) of the engine.
this was the answer I was looking for! I saw the parts on Pelican and really liked the looks of the carbon tube/cleanliness of the left side of the engine bay. Based on the consistency of these replies, this is one mod I will skip. Thank you for the great answers.
