964 Forum 1989-1994
C2 stalling in traffic
Old 12-13-2010, 06:03 AM
  #31
sandydiego
4th Gear
sandydiego's Avatar
hey, same problem for my car also...
unoccupied property insurance
Unoccupied House Insurance
Unoccupied Buildings Insurance
Old 12-13-2010, 06:54 AM
  #32
sml
sml's Avatar
I understand that. You said that before. I was just wondering what that little fan does and the logic on how it could impact the engine idle etc.
Old 12-13-2010, 11:56 AM
  #33
scped
scped's Avatar
Here is an additional cause of the erratic idle / stalling issue I had.
I removed the engine to replace the insulation, detail, paint the fan, ...) over the summer and all ran great afterwards. When the weather (here in NH) started to get colder, I had occasional fits of stalling / rough idling.
It turned out to be the throttle cable length. As the outside temperature dropped, the metal cable experienced "shrinkage" which in turn caused the microswitch to no longer make contact. A quick adjustment of the coupling under the car solved my car's problem.
Cheers,
Scped
Old 12-13-2010, 05:20 PM
  #34
Shamus964
Shamus964's Avatar
Cheers,
Scped
That's excellent to know, and funny to boot... problems caused by shrinkage!
One thing that Adrian mentioned in his book also, was the resonance flap being stuck in the 'partially open' orientation. You should hear it cycle when the key is in the 'on' position prior to startup if the vacuum line is working properly.
Old 12-15-2010, 08:44 PM
  #35
surfdog4
surfdog4's Avatar
don't people know about shrinkage?
Quick Reply: C2 stalling in traffic
