Hey Guys, lets rate some tires!
Ok I have searched the forums and found a milion opinions on tires for different cars. And after three nights of reading tons of different related chats, I still don't know what to buy. In our forums we seem to imput too much of what we felt like when we drove the car, rather than the way the car performed when we drove it. I PROMISE THERE IS A POINT TO THIS!
I found that Tirerack (no affiliation..., etc.) rates some of the tires they sell on a scale of 1-10 in a few different categories. But again these are based on the guys who drive a H@#$a C@#$c (Everybody OK?)
SO HERE IT IS: Ladies and Gentelman, this is the first tire rating forum that will provide all of 964/965 DRIVERS ONLY with the ratings of STREET PERFORMANCE ONLY tires based not only on the tire brand and model, but also based on the various rim sizes, as well as the suspension setup. So take a few minutes and rate yours. Then come back and watch others rate theirs. And every two weeks I will sum up the info and post results. This will be usefull for years to come.
Stan
P.S. If you wanna rate more than one, be my guest. Any suggestions on how to improve this are welcome!
I need:
CAR YEAR MODEL
SUSPENSION MODIFICATIONS: NONE, MEDIUM, RACE
TIRES BRAND, MODEL, SIZE
MILLAGE ON THESE TIRES
TIRE RATING:
Rating is on a basis of 1 - 10. Simply answer the question: How satisfied am I with:
1. WET TRACTION
2. DRY TRACTION
3. CORNERING STABILITY
4. STEERING RESPONSE
5. RIDE COMFORT
6. NOISE COMFORT
7. TREADWEAR
Example of an answer:
1990 C4 Cab
Susp :Medium
Bridgestone Potenza RE910 205/55/16 - 225/50/16
16000 KM
1. 7
2. 8
3. 7
4. 8
5. 9
6. 9
7. 9
To avoid getting bumped to a technical forum, please refrain from rating "track-only" tires.
Stan
I need:
CAR YEAR MODEL
TIRE RATING:
1. WET TRACTION
2. DRY TRACTION
5. RIDE COMFORT
6. NOISE COMFORT
7. TREADWEAR
1990 C4 Cab
Susp :Medium
16000 KM
1. 7
2. 8
3. 7
4. 8
5. 9
6. 9
7. 9
From: Philly Area ----- George Washington took a dump in my backyard!
1990 C2 Coupe
Susp: Med (Bilsteins / H&R / Lowered / Corner Balanced)
Toyo T-1R: 205/16/55 / 225/16/50
500 miles (200 at Watkins Glen, 3 track days)
Experience: 4 years / 20+ track days
1) 8 WET TRACTION
2) 8 DRY TRACTION
3) 7 CORNERING STABILITY
4) 7 STEERING RESPONSE
5) 6 RIDE COMFORT
6) 5 NOISE COMFORT
7) TREADWEAR Too Soon to Tell (it is for the track!)
1) 8 WET TRACTION
2) 8 DRY TRACTION
5) 6 RIDE COMFORT
6) 5 NOISE COMFORT
1990 C2 Coupe
Michelin Pilot Sport: 205/16/55 / 225/16/50
4000 miles (11 track days)
Experience: 4 Yr Street / 20+ days Track
1) 9 WET TRACTION
2) 9 DRY TRACTION
3) 9 CORNERING STABILITY
4) 9 STEERING RESPONSE
5) 8 RIDE COMFORT
6) 9 NOISE COMFORT
7) * worn out as a street tire in under 5000 miles - used on street & track!
1) 9 WET TRACTION
2) 9 DRY TRACTION
5) 8 RIDE COMFORT
6) 9 NOISE COMFORT
92 C2 Coupe
original suspension
Pirelli P Zero Assimetrico
225/50 ZR 17 255/40 ZR 17
15K on fronts 7K on rears
1. 3
2. 8
3. 7
4. 8
5. 9
6. 9
7. 6
Summary: These Pirellis are awful in the rain and while following a friend with some Kumhos that cost half of what the Pirellis do, I could not keep up due to serious hydroplaning over every spot of standing water. Very scary.
c
original suspension
1. 3
2. 8
3. 7
4. 8
5. 9
6. 9
7. 6
c
One recommendation: can the ratings include the category? For example:
1991 C4 Coupe
Suspension: Medium (lowered w/ Eibachs and corner balanced)
Goodyear Eagle F1 GS-D3
F: 225/17/45 R:255/17/40
20000 km (12000 mi)
Experience: 1 yr street/0 track events
1) 8 Wet Traction
2) 9 Dry Traction
3) 8 Cornering Stability
4) 8 Steering Response
5) 9 Ride Comfort
6) 9 Noise Comfort
7) 8 Treadwear
1991 C4 Coupe
20000 km (12000 mi)
1) 8 Wet Traction
2) 9 Dry Traction
5) 9 Ride Comfort
6) 9 Noise Comfort
7) 8 Treadwear
1992 C2 Coupe
no suspension mods
Yokohama ES 100s
255/40/17-205/50/17
1000 miles
1) 9 wet traction
2) 9 dry traction
3) 9 cornering stability
4) 9 steering response
5) 8 ride comfort
6) 8 Noise
7) too soon to tell treadwear
Comments-I've used the ES 100s on other 911s as well with very good results. I find them to be an ideal street tire and acceptable on the track. I was zipping along at about 100 in the rain yesterday with complete confidence. If wet driving is an issue for you, get these for sure. If not, I would get AO32s, but they wear quicker and they're not quite as good in the wet.
no suspension mods
Yokohama ES 100s
255/40/17-205/50/17
1000 miles
1) 9 wet traction
2) 9 dry traction
5) 8 ride comfort
6) 8 Noise
I have a bit of a problem with this but will try! The problem is, I would rate the tyres (please note the correct spelling of the word ) differently, depending on whether it is being used on the street or on the track. So I will rate them twice!
964 RS (ROW spec RHD)
Standard ROW RS spec, race geometry and corner weighted
Bridgestone Portenza S-02 - 205/50ZR17 and 255/40/ZR17
10,000 miles
Street use
1. 9 WET TRACTION
2. 8 DRY TRACTION
3. 9 CORNERING STABILITY
4. 9 STEERING RESPONSE
5. 9 RIDE COMFORT
6. 8 NOISE COMFORT
7. 9 TREADWEAR
Track use (once up to temp)
1. 10 WET TRACTION
2. 5 DRY TRACTION
3. 3 CORNERING STABILITY
4. 6 STEERING RESPONSE
5. 7 RIDE COMFORT
6. 8 NOISE COMFORT
7. 3 TREADWEAR
A bit of a difference!
10,000 miles
Street use
1. 9 WET TRACTION
2. 8 DRY TRACTION
5. 9 RIDE COMFORT
6. 8 NOISE COMFORT
7. 9 TREADWEAR
1. 10 WET TRACTION
2. 5 DRY TRACTION
5. 7 RIDE COMFORT
6. 8 NOISE COMFORT
7. 3 TREADWEAR
I'd also like to see another line entered in to describe the rater's experience. I know that in my own case I have just one year's experience driving these (this!) car so my opinions should be tempered with that fact. I also have no track experience. So, could we add an experience line above the ratings for street/track years in a porsche? I've edited my entry above.
Cheers,
Dave
Cheers,
Dave
1993 C2 Coupe
no suspension mods
Yokohama ES 100s
4,000 km (2,500miles)
1) 9 wet traction
2) 9 dry traction
5) 7 ride comfort
6) 6 Noise
7) no noticable wear
Comments-Quite sure these aren't N rated so not sure should be included. Although the tires have about 4000 km on them, these were made over the past 4 years. I've only had the car for 1,700km but feel the tires are noisy and hard feeling. Perhaps it's possible they've hardened since new. Thailand really beats up rubber products over time. Also, as it's my first 964 not sure the tendency to pull (left/right) on bumps ridges is common.
no suspension mods
Yokohama ES 100s
1) 9 wet traction
2) 9 dry traction
5) 7 ride comfort
6) 6 Noise
Originally Posted by Megatron-UK
Has anyone got ratings for Toyo T1-R's? I've used them before to great effect, but haven't seen them mentioned around here.
964 C2 Cab 94
Standard with LSD
Bridgestone Potenza RE750 - 225/50ZR16 and 245/45/ZR16
21,000 miles
1. 8 WET TRACTION
2. 9 DRY TRACTION
3. 8.5 CORNERING STABILITY
4. 8.5 STEERING RESPONSE
5. 8.5 RIDE COMFORT
6. 7 NOISE COMFORT
7. 9 TREADWEAR
Yokohama Advan Neova
225/45ZR17 255/40ZR17
1. 8 WET TRACTION
2. 10 DRY TRACTION
3. 9.5 CORNERING STABILITY
4. 9.5 STEERING RESPONSE
5. 7 RIDE COMFORT
6. 6 NOISE COMFORT
7. 6 TREADWEAR
Standard with LSD
21,000 miles
1. 8 WET TRACTION
2. 9 DRY TRACTION
5. 8.5 RIDE COMFORT
6. 7 NOISE COMFORT
7. 9 TREADWEAR
1. 8 WET TRACTION
2. 10 DRY TRACTION
5. 7 RIDE COMFORT
6. 6 NOISE COMFORT
7. 6 TREADWEAR
CAR YEAR MODEL: 1991 C4
SUSPENSION MODIFICATIONS: NONE, MEDIUM, RACE: Medium (see signature)
TIRES BRAND, MODEL, SIZE: Michelin Pilot Sport 205/50/17 and 255/40/17
MILEAGE ON THESE TIRES: 13 000 km (including 18 track days)
TIRE RATING:
1. 7
2. 9
3. 8
4. 7
5. 8
6. 8
7. 7
Uh, it's already in a technical forum.
Marc
TIRE RATING:
1. 7
2. 9
3. 8
4. 7
5. 8
6. 8
7. 7
Marc
