Update: Unwanted heat in sills left & right...
Hi,
(I'm living in Holland so forgive me my English grammar...)
I'm new to this Forum and also new to 964 ! Driven SC's for the last 12 years and finally changed to a '91 964 Tiptronic. Really a great ride and the AC and sunroof option is also nice with this kind of weather.
But I noticed something weird...
When the engine is very hot my rear blower is also working to help cooling the engine (I understand this is normal...). The fan in the front at my oil cooler is also working (both speeds..).
Strange thing is that left and rigt sills (is this the right word for it ?? I mean the hollow body parts where warm air is also going through while the heater is on..) are also become hot. The heater is off and no warm air is entering the interior at the dashboard... Also the AC is working fine.
Is it normal that these sills become warm when the engine blower is working?
Hope you can help.
Regards,
Dick911
Hope you can help.
Regards,
Dick911
Burgled
The oil heats up the right side sill and fender. Never noticed if the (driver) left side got hot.
Welcome and show us some pictures of the car
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The oil pipes that transfers the oil from the front cooler to the engine run down the right side of the car, so the passenger sill is typically warm, if not hot. I have never experienced the same kind of heat on the left hand sill.
Thank you all for your replies.
I know the oil lines and cooler are on the right side of the car and also running through the sill towards the front wing.
But I've the weird problem that both my sills are warm, not by oil lines but I think they're warmed up by hot air pushed forwards by the blower in the rear at the engine.
Some mechanic told me this is normal because the rear blower dumps the warm air from the engine in the rear wheel arches but also in the sills...
At the front of the car the warm air which is not needed, will leave the car at the underside...
Is there somebody out there who can confirm the above mentioned story by the mechanic?
Thanks in advance!
Dick
Thanks in advance!
Dick
Technical Guru
![](https://members.rennlist.com/jandreas/HeaterDumpValveOpen.jpg)
![](https://members.rennlist.com/jandreas/HVAC-MixingChamber.jpg)
![](https://members.rennlist.com/jandreas/MixingChamberServo.jpg)
![](https://members.rennlist.com/jandreas/HeaterDumpValveClosed.jpg)
![](https://members.rennlist.com/jandreas/HeaterDumpValveOutlet.jpg)
Jason,
Impressive set of diagrams! When I finish my other 800 projects, I have to look at why I get hot air in the cabin even though the heat is off. This will be a great help when the time comes! I wonder if maybe my dump valves are seized up? Maybe I should have a look in there while the engine is out?
I assume these are part 964 572 087 00 & 964 572 068 00 in pet?
This might be Dicks problem as well if the dump valves are not closing and the hot air is only being stopped by the front air flaps?
Kirk
Kirk
Technical Guru
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Hello Jason (and Kirk),
Many, many, many thanks !!! The pictures and the flow diagram makes it all clear to me.
I'm going to check the dump valves. In the front of the car is no warm air noticeable so the mixing chamber at the front seems to be working fine.
Thanks again,
Dick964
PS: what stands CCU for in English ?
Thanks again,
Dick964
With all the new information from this great forum I did some research yesterday evening at the dump valves and other mentioned parts.
But I also noticed something else:
The sills only become warm when I'm driving with my sunroof open !
When I close the sunroof and wait (still driving) for about 3-4 minutes the sills cool down again...
Is it possible that my interior temperature meter (?) is giving false information to the CCU ?
Greetings,
Dick964
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Greetings,
Dick964
I'm guessing here, but since the flapper boxes are operated by differential air pressure, opening the sunroof is likely to change the air pressure situation completely. Opening the windows is likely to have a similar effect I would guess.
I'm sure someone else could explain in detail.
Regards
Dave
Regards
Dave
