radio static - just right front speaker
After replacing my original head unit in my 90 C2 I noticed static coming from the right side. I've been living with this for a while but I can't stand it any more. This is what I know, it is only the right front speaker. I don't get much a idle but the static comes in around 2,000 rpm and get louder by 4,000 rpm. It is a static sound, not a whine. The other speakers don't sem to have any static at all. Even with I move the balance and fader away from the right front I still hear it, it doesn't make a difference. Only when I disconnect the speaker does the static go away. It is not related to radio or CD, it is a constant, even when the volume is down. Only by making it very loud can I overpower the static. Any ideas? I had wondered about the noise supressor added after my model, but I never had a problem with the original unit and why only one speaker?
Could it be a blown speaker?
I might also suggest a new chassis ground at the stereo. I had alternator noise in mine and re-grounded to a different location, under the passenger seat, where there was a factory ground. Noise is gone.
The connections to the speaker appear good. It is an original speaker so the surround is falling apart, but I don't think that could cause this. I have been looking for replacement speakers for a long time, but can't find anything that will fit with the stock grills. They all seem to come out too much. I will check the ground at the head. It is attached, but maybe not good at the other end.
It might be the fact that you routed the wire alongside an electrical current of some sort which is why it is only affecting that speaker - just a thought why not take the wiring away from its present route and see what happens.
I was able to fit 6x9's in the rear deck by cutting out the factory holes. Sounds MUCH better. More bass.
I did swap the left and right speakers and still had the problem so it doesn't seem to be a problem with the speaker itself. That said, I plan to replace them anyway. I still have to trace the wiring and will look to see if it is placed against some other wire that could be causing interference.
