flywheel / speed sensor gap on 90 C2
I have read a lot about this gap but haven't found anything in the manuals or PET or anything so far in the posts that I can positively identify as the correct gap for this.
Is it 1mm +/- .2mm ?
Mine did not come with any shims, just bolts onto the case, but the bolt holes obviously allow an adjustment for how close the sensor is to the teeth.
Technical Guru
Wow there it is - never would have thought to look under "DME diagnosis / troubleshooting" - you're the man, Jason!
Guess I'm going to have to print that bad boy up and start reading it on the toilet in my spare time...
