heat always on?
heat always on?
no matter what settings I have on my 964, my heat is always comming out of the vents.I know its a complex HVAC system on these cars but I was wondering if i deleted the aux. heater blower with the cup heater bypass would this solve my problem?just wondering.
Sounds like you have a bad blend motor. I had the opposite problem, always cold, the drivers side blend motor was bad. There is an article to how to fix somewhere on here.
Cheers
Mark
Cheers
Mark
There have been several threads on this topic. Here are a few:
https://rennlist.com/forums/showthre...***+blower+cup
Technical Guru
thank,I just figued that out when i unplugging the rear motor,it didnt make a difference.heat is still comming out of the drivers side and middle vents. kind of annoying now that its 80 deg out
