Schnell Front Strut brace
I just installed a Schnell front strut. pretty easy to install and did not have to cut the carpet which will lay right over the strut. Only issue was the strut comes with a lock nut at each end causing the length to be about 1/8 inch too long. had to remove one of the nuts to be able to align the strut bracket holes with the two bolts on the front shock base. The quality of the strut was very good for the price, $135, and I did seem to notice a diffference going over bumps, less bouncing. Next step will be new shocks. Also installed the Aluminum pedals from Ultimate Pedals. Nice fit and look good.
Don I installed the same strut brace two weeks ago on my Targa. There should no length issues. Meaning there should be no reason to remove the lock nut ... there should be plenty of adjustability in length with the lock nut on. ALso it is a good idea to put the lock nut back on ... as over time the bar could unscrew itself or at least loosen.
hey Hawk, you must be real busy if I got something on before you did. Did you get the driver foot rest too? The first one they sent me was for an earlier model 911 which did not have a formed driver foot rest. If you get one, make sure they ship the one for a 993.
Carrera Cup, not sure why my strut was too long unless they sent one for a 993 which I believe is 2 inches wider than a 964. The brackets that came with the strut had one fixed hole and one adjustable hole. If both holes had room for adjustment, it would not have been an issue. Right now with one lock nut screwed tightly down and no lock nut on the other end, it just fits. I plan to open up the fixed bracket holes to be able to get the other nut on.
Technical Guru
Hawk, I just put mine on after they resent the 993 model, it fit perfect. Call Rob at Ultimate Pedal and ask him for the same one he sent me, refer to the shipment to Shaker heights, ohio. Just mention the conversation he had with me when we concluded he sent me a dead pedal for a pre-89 911 which doesn't have the foot rest. The 993 dead pedal fits fine. I'm sure Rob will remember our conversation. If you need specific demensions of the one that fits, let me know.
