Total 911 article on 9M heads
#31
Location: WhippetWorld, .........is it really only this many
1 Post
Originally Posted by robmug
Geoff - OK, I get it. My take on it is that the heads are what restricts the ultimate power gains achieved; so at xxxbhp the heads are what stops a tuner going any further.
#32
Tonytaylor,
I did not know that there was that much difference between 964 and 993 head porting .
I know that my motor , 285 993 , has bigger valves , so I guess different ports ??
Maybe a 911 Head expert can tell us ???
Geoff
Geoff
#33
A 964 head has a 41mm port and a 993 head has a 43mm port so it is larger, however the air velocity is slower, especially on the 95 head which has the same size valves as the 964. If you measure the port volume the 993 is significantly larger all of which slows the air. The 96-on 993 heads have larger valves, the RS has larger yet, and teh RSR sprint engines have 54mm intake valves. All RSRs have 45mm ports. 993 have 8mm valve stems where 964 has 9mm valve stems which cause additional restriction over 8mm. 9M heads have are designed for 8mm valves. In all of the replacenment heads I do, I use 8mm.
#34
You have 9M heads on your 993 ? Any power figures ?
c
