964 Forum 1989-1994
Next weight saving project
Old May 10, 2006 | 06:00 PM
  #31
FamilyCar's Avatar
FamilyCar
Why not just get an aluminum hat w/ floating rotor. I bet the weight savings would be greater.
I'm installing such a set up front in a few weeks for use w/ big reds. I will weigh the new set up. Once the solild 1 pc comes off I shall weigh that as well and post the weights.
Old May 10, 2006 | 07:13 PM
  #32
N51's Avatar
N51
Originally Posted by FamilyCar
Why not just get an aluminum hat w/ floating rotor. I bet the weight savings would be greate.
I'm considering this but wonder about the overall weight savings considering the larger calipers. I've been unsuccessfully searching for a rotor replacement for my stock setup but using aluminum hats.
Old May 10, 2006 | 08:22 PM
  #33
jeff522's Avatar
jeff522
I still say one of the best weight savings would be the driver loosing some weight.It would have to be safer than drilling rotor hats.
Old May 10, 2006 | 08:27 PM
  #34
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
You can find floating rotors here but they are not for a stock setup.
Marc
Old May 10, 2006 | 09:05 PM
  #35
FamilyCar's Avatar
FamilyCar
N51,
You are probably correct. One would need to know the weights of standard v big red calipers as well, to know for sure. I already had big reds, so going w/ the aluminum hat/floating rotor from 965 1pc rotors was an easy decision from a weight reduction standpoint.
I am not aware of an aluminum hat for the stock diameter rotor, as I haven't looked into it. It seemed like it was worth bringing up though.
Old May 12, 2006 | 06:00 AM
  #36
pauline964's Avatar
pauline964
kgorman
....There is a fine line between 'smart' weight savings and 'sickness'. Seek help!
excuse me, you call me sick?????????
jeff522
I agree with you when it comes to driver's weight, I am OK there, that's for sure
As posted before, I'm using two piece rotors at the front, without hat
one rotor is 15,43lbs (on my scale). The rear org. rotors have the the same
weight.
Unfortunately, there is no company out there, that is doing a two piece rear rotor like the original one ( I need handbrake for TÜV).
