bad noise on start up
#32
i have the noise and am gettin ready to do valves and gonna check the tensioners...have a bunch of jobs to do...
but thought maybe the persistant noise could possibly be a flywheel failing??
attached some threads referencing the 'noise'...
http://forums.rennlist.com/rennforu...ad.php?t=271491
http://forums.rennlist.com/rennforu...ad.php?t=291075
https://rennlist.com/forums/964-forum/351945-sounds-like-rocks-at-startup-after-sitting-for-weeks.html
later
later
#33
later
later
BTW boze_man, I got a 404 error on your links.
#34
i have heard my noise between shifts...not sure if the noise is drown out by the motor under load or if it just returns at shift...
lets try the links again...
https://rennlist.com/forums/964-forum/271491-cold-start-jangling-noise.html
https://rennlist.com/forums/964-forum/291075-cold-start-buzzsaw-sound-i-need-to-fix-this-asap.html
https://rennlist.com/forums/showthread.php?t=351945
#36
Originally Posted by ddubois
I spent some time today with the plastic hose listening around during cold start up, and I'm changing my diagnosis. I'm thinking this noise that I thought was the chain tensioners is in fact the starter gear hanging up when it's cold. The fact that this problem goes away when everything is warm has me thinking the cold and hardened grease is the culprit. I searched around on the forum and didn't find much with regards to sticking starter solenoids, so I'm going to remove the starter tomorrow and hope that's the problem (cheap fix assuming it's a simple matter of regreasing the pinion shaft.
