RS ride height (according to the Porsche Workshop Manual, pages 44-02, 44-03) is
F: 125 mm +/- 5 mm
R: 223 mm +/- 5 mm "From road contact surface to meas. point at control arm (mm)" OR
R: 235 mm +/- 5 mm "From road contact surface to meas. point at outer control arm mount (mm) (body side)* Use this measuring point, if it is available"
So I'm not sure where the 218 came from (it is not RS + 5 mm as suggested).
Marc, my car is RS +/-5mm, the dimensions given were RS in Adrians book for an ROW car.
218 at control arm, 230 at outer control arm. page 262 of Adrians book.
You will have to ignore page 18 on the write up, it's stuck in the Pipex cache and they are not helping me shift old data, they have also not helped in allowing me to ftp my data up, so the info is squiffy on that page, I've tried to sort it out over the past few days, but am having no luck in gaining access to my site.
Mark, are the pictures showing up for you? I just clicked on it and it doesn't look like they are appearing, but it might just be me. If not, then I'll have to check with my host.
Kevin - is it the "Euro RS" that Adrian refers to in his book (set lower than regular RS)?? Your Pipex page says you set it at RS + 5 mm (suggesting RS was 213 mm). Is it possible you meant RS - 5 mm for regular RS or is it actually Euro RS so + 5 mm?
Jeff - I looked a few times earlier today (to see the 993 rear measure point you asked about) and no pictures showed up.
