Ride height measure points
Jeff, most pics show if I click on the link-box thingy (with the red x). ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Some don't, like the measuring point pics.
I assumed the problem was on my end since microsoft firewall crap has been giving me fits lately.
Originally Posted by Marc Shaw
Mark,
RS ride height (according to the Porsche Workshop Manual, pages 44-02, 44-03) is
F: 125 mm +/- 5 mm
R: 223 mm +/- 5 mm "From road contact surface to meas. point at control arm (mm)"
OR
R: 235 mm +/- 5 mm "From road contact surface to meas. point at outer control arm mount (mm) (body side)* Use this measuring point, if it is available"
So I'm not sure where the 218 came from (it is not RS + 5 mm as suggested).
Marc
F: 125 mm +/- 5 mm
OR
Marc
Situation normal.
Technical Guru
There is a thread from last summer with photos of the factory measuring points but I can't find it or the rear photo I took. If pipex can't get their act together with Kevin's photos I can shoot some photos of the rear measuring point again.
![](https://members.rennlist.com/jandreas/FrontRideHeight.jpg)
Super Duper Moderator
Would you mind shooting that picture of the rear suspension measuring point? I'm just setting the ride height formy car but I am finding it awkward to access the correct points.
Thanks.
Marc
I'm just a simple guy - I made a simple gizmo to easily measure the ride height that maybe everyone already knows about. I will post a picture as soon as I get my camera unpacked.
I used a short piece of 3/8" ID tubing (about 115mm long) and slipped a 120mm piece of 3/8" all-thread with a nut inside the tubing. Just stick it under the car at the measuring point, turn the nut to extend the length of the overall assembly til it touches the measuring point and the ground. Pull it out and measure the overall length. Use a longer piece of all-thread for measuring the rear points. The pictures will make it more simple/obvious, but you guys should get the idea. No need to be a contortionist and try squinting under the car.
I discovered that my car was set at near the RS specs, slightly under. I think it was actually hitting the stock bump stops, explaining the harsh ride with the H&R red Turbos. The Bilsteins have let me raise it a bit, although I'm not finished with it yet. (I just moved out of my house, and I can't find any of my shtuff.)
Darrell
Darrell
Technical Guru
![](https://members.rennlist.com/jandreas/964-RearRideHeightPoint.jpg)
The "cast boss" should be about a 12mm lower than the "body end measuring surface."
Resurrecting an old thread… Question on this measuring point for front ride height… is it from the bottom of the nut to the ground? Thanks.
That’s much fancier than with what I came up with. I took 2 plastic drinking straws and cut them down so they’d fit under the car. I put one straw inside the other and made an adjustable height straw. Whatever the length of the straw was from the ground to the measurement point on the car was the ride height.
TomJVW (07-24-2024)
