rear 4x6 speaker
Great pics - wish I'd seen this before i started on my replacement! However it was pretty straightforward - bought some JBL GTO6429 - £40, pulled back the rear shelf to make access simpler, prised off the existing grills, unscrewed the original Blaupunkt speakers & binned them - but kept the grills.
These JBL's screw straight into the same holes, wired up, tested, then shelf re-fitted.
The grills now don't fit because there's a collar raising the height of the fitted - these collars will simply pry off - meaning the grills will now fit flush. However the original grills are marginally larger than the new speaker frame - i used some double-sided foam tape to glue the grills in place.
30 mins later job done! (15mins were spent finding black double sided tape that i just _knew_ i had...)
These were the speakers:
In reality they were closer in looks to the ones in the thread above - where the frame can be dismantled - although I didn't bother dismantling - the pics in the link looks like a single piece frame for some reason.
