Engine Out successful, small glitch
Thanks everyone for the assistance on the Dmf and clutch job.It started fri nite at 6 and ended sunday nite at 6. The power steering was leaking as well as the large seal behind dmf and smaller one in tranny. All replaced succesfully with breather seals , new oil pressure switch ,clutch slave, clutch rod parts and related seals,bearings and gaskets. Leaky chain cover gaskets also redone. The new dmf and clutch is very nice to have. Started first turn and runs well except for check engine light on. Read code from pedal and its 1115, something about Idle speed contact ground short. Does anbody have any ideas? Thanks again Doug
Technical Guru
