964 Forum 1989-1994
how's my electrode look: worn out!
Old 03-23-2006, 05:16 AM
Hambisa
Hambisa's Avatar
Garrett;
What brand and model # plugs did you get for the replacements?
BTW: are you still going to the Zone 8 Speed Festival this weekend?
Old 03-23-2006, 06:43 AM
Kavo
Kavo's Avatar
Geoffrey, which plugs do you recommend for performance?
Old 03-23-2006, 07:52 AM
springer3
springer3's Avatar
Garrett:
Good call. Besides the worn electrodes, the threads have lost some of the corrosion protection and finish. Push plugs too long, and you risk damaging the heads or other parts if the ignition system. If a $60 maintenance item once per year is too much of a a bite, we should probably switch to a 4-cylinder economy car we can afford to maintain.
Old 03-23-2006, 08:15 AM
Geoffrey
Geoffrey's Avatar
I like the Denso Irridium or the NGK Irridium plugs.
Old 03-23-2006, 12:31 PM
garrett376
garrett376's Avatar
Originally Posted by Hambisa
Garrett;
I got whatever the $5 Bosch Super plugs are from Pelican Parts: 999-170-183-90-M14
http://www.pelicanparts.com/catalog/..._pg1.htm#item3
Yes sir!! I drove the car this morning to be sure it was ready for action!! After a brake pad swap, I'll be heading up early Sat. morning!
Old 03-23-2006, 12:51 PM
Indycam
Indycam's Avatar
"Good call. Besides the worn electrodes, the threads have lost some of the corrosion protection and finish. Push plugs too long, and you risk damaging the heads or other parts if the ignition system. If a $60 maintenance item once per year is too much of a a bite, we should probably switch to a 4-cylinder economy car we can afford to maintain."
Do you know that some plugs are now rated to 100,000. miles or ten years ?
I've never had a plug damage a head on any of my cars .
I keep my plugs filed and gaped so no extra ignition strain .
I really do not like getting rid of things that work fine or spending money replacing things that work fine . As for the little zinger about what we should own , I have a few brand new sets of factory plugs
awaiting the day when they are needed , until the old plugs are truly in need of replacement , the new plugs will stay in the factory fresh porsche boxes that they came in .
Old 03-23-2006, 12:53 PM
dfinnegan
dfinnegan's Avatar
Anyone know what the difference is between the Bosch and the Beru. Both are on the same page that Garrett referenced above.
I suppose this is sort of like the oil debates, but I don't know much of anything about plugs and was wondering why the Beru are twice the price.
Old 02-20-2008, 06:48 PM
Fast4525
Fast4525's Avatar
Almost two years on. Is this still your suggestion for a street and track driven 964? Do these thin electrode plugs last as long as the OEM Bosch plugs? Do you feel there is a measureable performance gain vs OEM?
Old 02-20-2008, 08:21 PM
elbeee964
elbeee964's Avatar
Default Tri-lobed? Try harder!
Garrett-
Hi. That red car you helped me tear into about 4 months ago in your driveway had tri-gap plugs like yours when I had its PPI done. The PPI guy gave me a glowing report... except for the spark plugs. He said they needed replacement -- about 30-40k miles ago! lol
Their anode (cathode?) post was a little more tri-lobed than yours. (ahhh -- but not by much... ) I kept one of 'em for giggles, but it's packed away somewhere now.
At the time I was considering backing away from the buy because of that tell of potential maintenance neglect. But I went through the receipts and damned if the previous owners had done everything BUT plugs. Weirdest thing I've ever seen.
Knowing your cars see engine drops more frequently than most any other I know of, () engine neglect just isn't in the cards.
But replace the plugs, G. And thanks again for your Hammer-time.
-Lonnie
Old 02-20-2008, 08:37 PM
elbeee964
elbeee964's Avatar
Talking
Originally Posted by dfinnegan
...Anyone know what the difference is between the Bosch and the Beru. ...was wondering why the Beru are twice the price.
My tri-cathode Beru's had "France" stamped on the side. True.
[me, biting tongue.]
Old 10-31-2013, 08:43 PM
Vandit
Vandit's Avatar
Dude, WTF....
I bought these spark plugs recently (NGK BPR6EIZ 6637) because everything I checked online said that these plugs fit the car. I was going to install them this weekend, so today I was getting my socket-game sorted when I realized these new plugs take a 13/16 socket, not the 5/8s like what I expected and like what's currently on the car.
NGK BPR6EIX Iridium IX Spark Plug : Amazon.com : Automotive NGK BPR6EIX Iridium IX Spark Plug : Amazon.com : Automotive
I assume that these won't fit and I should return them? I could barely even get a 13/16 socket into the opening on the valve cover.
Old 11-01-2013, 12:47 AM
Vandit
Vandit's Avatar
Studying the images on the PelicanParts ignition catalog, it would appear the plugs I have would work on a 3.3l Turbo.
Old 11-03-2013, 12:41 PM
Vandit
Vandit's Avatar
I ended up going with the Denso Iridium 5310 IK22.
http://www.densoproducts.com/product.aspx?zpid=11179
Hopefully they'll come in this week and I can move forward with installing the during the weekend.
Old 11-03-2013, 01:01 PM
Vandit
Vandit's Avatar
Originally Posted by Vandit
Dude, WTF....
A bit more info regarding larger base (13/16) plugs versus the 5/8 ones that our cars use.
https://rennlist.com/forums/944-turb...ark-plugs.html
While it seems either can be used on an 944 Turbo, I doubt that is the case on the 964. The space confines would make it impossible to get a 13/16 socket lined up and inserted into the holes on the valve covers while the engine is in the car.
Quick Reply: how's my electrode look: worn out!
