Power Window Adjustment Cabrio 1990
Pulled my inner door panel to look for an adjustment mechanism for my drivers side window and I am stumped. The rear corner of the window rides up and over the window seal at the cabrio top causing a leak. I have to lower the rear corner about a 1/4" so it will butt up underneath the seal. Has anyone had a similiar problem and what's the fix procedure. Workshop Manual references as of 1993.
" Adjusted" for a pre 93 there is a oval slot just to the right where the door handle mechanism - actuating rod is located. Had the window about a third of the way down when moving the adjustment bolt back or forth. It seemed to work easiest in that position. Sorry no pics.
