Racecar Project - Head Flowing
#31
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by Geoffrey
My goal here is an engine that produces 380hp, operates in a range of 5000-7800, has a nice flat torque curve in that range, and runs on 93 octane street fuel.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#32
Originally Posted by Larry Herman
Well all you have to do is get a GT3 down to 2100 lbs. You don't even have to touch the motor! It's amazing what 2 extra valves will do.
Noah
#33
I've done some work with the 4 valve engines and they are far better than the air cooled engines in every respect including cost, except for weight and produce more power and torque across the range. A GT3RSR is listed at 2400lbs and I know Rick Deman's freshly built GT3RS weighed in the 2500lbs range, so getting much below 2400lbs is going to be very difficult if not impossible using normal manufactured parts.
I had considered installing a modified GT3 Cup engine into my chassis, but I didn't want to deal with the extra weight penalty.
VE% = Volumetric Efficiency - The theoretical maximum amount of air that each cylinder can ingest during the intake cycle at a given RPM. VE will change based on engine load and engine RPM and will mirror the torque curve of an engine. 100% VE is equal to the volume or displacement of a cylinder or an engine depending on what you are measuring. Ignoring the fact that a 3.8l engine is quite 3.8l, 100% VE for a 3.8l (231.89ci) engine operating at 6000rpm is 231.89 x (6000/2) / 1728 which gives you 402.59CFM of air. On an engine dyno, if you had an air turbine measuring the incomming air through the intake system if you saw 402.59CFM at 6000RPM, then your engine would be operating at 100% VE. Volumetric Efficiency is really a poor choice of wording although it is the industry standard termonology. My reasoning is that the cylinder always has the same volume of air, it is the density that changes, so really it should be called massemetric efficiency.
NVR = Non VarioRam intake (I'm guessing here)
#34
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by N51
Not given Bob Linton's resources, is that possible - a 2100# GT3? Geoffrey's approach would, I think, be far less costly.
#35
After spending the last hour reading all of the Racecar Project posts I am
Very very impressed
I think i will start to embark on a mini-Geoffrey project for the street
The level of thought here takes me back to my FSAE days. Prove everything you do.
I did some similiar research on port flow in school and it is a safe assumption to go with imcompressible flow when doing calculations based on flow bench numbers
Very very impressed
