Primary AND secondary bypass?
Hi Graham - download quicktime to view it:
http://www.apple.com/quicktime/download/mac.html
If you're a windows guy, there's a link to get it, too![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I must say, that the exhaust config of no cat, hollowed out primary, no secondary, and open airbox does make me a little deaf after a 15 minute drive where I am going through the gears (not freeway cruising). Above 4000RPM the thing howls! It's wonderful.
On the freeway, it's just fine - not bad at all, actually. The completely stripped interior and engine bay, and open airbox cover are probably what makes the most difference on the interior noise...
given that I seem to be selectively putting emhasis on the posts that encourage me, I'm going to assume that most of your noise 'problems' come from either the stripped interior or the airbox (!)
Thanks Guys - I havent decided what I'm going to do yet, but when your friends have TVR's it's easy to get sucked into this kind of mod- they do place a lot of emphasis on the sound of the car.
EDIT - Have just watched the 'wake the neighbours' clip - very impressive. I REALLY like that a lot. Thank you!
My $0.02 is that if you want to get an idea of what it would sound like is to just disconnect the system where the primary muffler meets the catalytic conerter. Thats pretty much the sond youll have with the two bypass pipes. I an running a"Shubert" Primary Bypass with the factory Scondary Muffler. This bypass is suppisedly made either for or by DP Motorsports. I got it on eBay for $300 (about the price of a primay bypass) and it has a 6" resonator instead of a muffler between the bends and keeps the car legal while giving a nice rumble.
lol - not quite decided, i think at the moment it depends on some other work i need to do to it:
little rust bubble needs fixing
calipers need painting/decals
service/MOT before Le Mans
if the above go to plan then I'll do it, just to try...if the service turns up anything untoward then it'll have to wait.
Hows the rebuild going?
What about removing the secondary muffler and using either disc type incerts(like 2 disc Car Chemistry)or a tunable muffler(Supertrapp)both options offer minamal restriction and will help reduce sound.Hot roders have been doing this for years to run open headers or with a single chamber race type muffler.If it will work with a rat motor it should work with a 3.6lt.
Graham L
I run with both mufflers bypassed. I have a stock cat. My car is primarily a track car although I do drive it on public roads occasionally. I am kind of surprised that it is not loader than it is. I wonder if someone lives near me that could make a recording of the sound. I tend to be a little more hard core than most but I don’t think it’s that bad under normal driving conditions.
Ditch the cat and fit a bypass pipe to replace it, also ditch the primary silencer/muffler across the back of the car behind the bumper, and replace with a Cup pipe (the primary silencer is heavy and inefficient). The secondry "suitcase" silencer is efficient at silencing and is good for HP.
Drill your airbox and you'll have the best mix of exhaust noise at tickover (low and bassy) and plenty of induction noise when you give it some beans !!
Good luck with the servicing.
come on! that should be below exhaust mods in priority!!
My car is still in many pieces - bottom end in uxbridge, heads in cheshire, suspension in arizona
i'll update my old thread when its getting nearer completion though
I have a 91 3.6 installed in my "Older" 911. Running headers going directly into Spin Tech mufflers. (similar but smaller then supper trap). Very loud with a great rumble at idle and screams over 4000 RPM. Cruising at 3K on the higway is tolerable for long rides. I think it could drown out a Harley.
Originally Posted by Kavo
Graham L
I've done bypass pieces aft of OE cat, so no mufflling at all.. Although very much a personal taste issue, imho I think the detractors of this setup are wrong. Sound is very healthy. If you've heard a Duc Superbike with large bore Termignoni's, this is very similar imagining said Duc to the 2nd power.
Loud ? Admittedly. Healthy ? Very. Local Porsche shops and club folks have loved the music, as do I ! Can I sneak the car in after a late night boozer ? No bloody way.
Is this loud around town when mashing the loud pedal, well, yes to that. I'm careful not to really do the full Italian tune-up where it might offend. But, I want to hear the damn motor very deliberately and in detail.
I'm happy enough with the sound such that I've got a Dansk Euro pre-muffler on order from DPS Motorsports ($280, btw) to complete this very free exhaling set-up. The car admittedly is evolving into more track special than boulevardier.
Aficionado
Originally Posted by Graham L
i dont think the secondary makes too much noise, so more would be more 'dramatic'...this probably means that either i have become completely immune to exhaust noise or the secondary has made me deaf and now i need more!
Is it really THAT bad?
You want them straight ? good luck.
