What the hell is this thing?
Technical Guru
The clicking sound comes from the contacts inside the alarm control unit relay, opening and closing. Your battery voltage has probably dropped below 11 volts and that causes the "relay coil to pull-in and then drop out continuously." I had the same problem, try recharging your battery and you should be okay.
