behavior of failing O2 sensor?
I am curious, when the O2 sensor is on the way out, does it (or can it) act intermittently? I will get a check engine light every once in a while - sometimes at idle, sometimes at a different speed, like 2880 RPM. I will check the code with the Hammer and it tells me that the sensor error is due to the O2 sensor open circuit/not present. But when the check engine light goes on, it will go off in a few seconds. The car drives perfectly, even when the light goes on, then goes off. I can watch the values of the O2 sensor while driving - it seems to oscillate just fine. It just keeps throwing a fault every once in a while, always the same error, according to the Hammer.
Is my O2 sensor on its way out? The wiring seems intact, as the plug is firmly attached... I guess I can swap out the sensor from my other car to check, but I thought I'd check with you guys first! Thanks
It sounds like you have an Intermittent open . It might be going open for a millisec or less . You might not ever see it but the computer might . The open could be anywhere , from inside the computer back to the O2 sensor and then back to the insides of the computer .
Tracking down something like this , an Intermittent/Intermittent , is a test of your skills . Step by step , you can hunt it down .
You could do what the guy up north did , unplug the O2 sensor from the computer
and then redo the settings inside the DME so that the computer does not look for an O2 sensor .
I posted a DIY article for 02 sensor change... It has a link a link where I purchased mine for a great price! Hope it helps!
https://rennlist.com/forums/diy-964-1989-1994-911/208133-diy-oxygen-sensor-replacement.html
Wow Rick, that is one long thread for unscrewing one thing!!! Well documented!!!
How does your el-cheapo sensor work from www.autopartsworld.com? I've heard of cheaper O2 sensors not being the right type, especially if they get wet. Has it worked OK for you? Thanks
