Nology Hotwires Ignition wires
hey,
its all bull****. just dont do it.
the stanard wires are the best you can buy, they all have exactly the same resistance because the resistance is in the blug connectors not the wires. but every aftermarket wire set run usually a carbon or such wire and this is the resistance. in which case evry wire has a different resistance because of its different length, and they use cheap nasty plug connectors.
Sean Buchanan
Buchanan Automotive
Sean Buchanan
Buchanan Automotive
A friend rented a dyno for a day to test various things on his Spec Miata. The Nology wires actually resulted in a slight power loss compared to the OEM NGK plug wires. Magnecore tested the best. This isn't an apples to apples comparison for a 964, but thought you might find it interesting.
My tech said the only significant improvement to be made (aside from forced induction or something equally dramatic) is intake w/ exhaust and possibly remapping. Remapping will, of course change the behavior of the engine management somewhat - so performance will be at the expense of fuel economy or changing the power band may lead to "flat spots" elsewhere, etc. Everything has a trade off.
Thanks guys. I just saw it on one of the websites for Pcar parts and was wondering about it. Not looking for more power. Although a WRX did keep me from overtaking him at a traffic light. Damn those subarus are fast. I couldn't climb on him enough to get past him. And my C2 Cab was dynoed at 245 just a few months ago. Maybe it's time for that chip and exhaust upgrade.
