Oil Level Gauge Readings
#31
Originally Posted by Slappy
... I check my oil ONCE a week ... (when its not stored away for the winter months).
#32
Love your list Springer !!!
BUT ...
the oil gauge CAN lie/fail ... the dipstick NEVER lies/fails.
BUT ...
#33
Hi all ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
[I just bought a 964 Tip too (1990 guards red). I am the second owner and the car has less than 40000km on it as the previous owner dont drive it much.]
Anyway, was reading about the problem as my car's oil guage seem to be behaving the same until recently. Was worried until I checked the dipstick.
This website (http://www.porsche964.co.uk/) mentioned it could be due to the "oil level sender". It also suggested a solution. [ http://www.porsche964.co.uk/technical/oilsender.htm ]
Hope it helps.
Cheers.
Hope it helps.
Cheers.
#34
Ruf Dallas told me the gauge is more accurate than the dipstick....contrary to all that I've read here on Rennlist
#35
Is the dipstick that wire thing with different levels shown on each side when the oil is dirty enough to see anything !
Favorite are the people who use the stick with the motor off !! and then put another gallon of oil in !!!
Geoff
Geoff
#36
Technical Guru
#37
I would love to see pictures of a dipstick oil reading. Or, better, watch someone read the stick and see what they see. I'll be damned if I can get a good reading off the thing. It's never the same twice!
#39
Good Idea Marc!
I've noticed that until the oil is nice and hot, at idle for at least 30sec., at level ground, I will be able to get a very concordant reading between the dial gauge and the dip stick.
Jaime
Jaime
#40
I've noticed that when the ambient temperature is cold that the oil level will always read low (dipstick or gauge). The oil probably never gets warm enough to get an accurate reading? As soon as the weather warms up it starts to read the right level again.
(for those who drive their P-car in the cold of course
#41
Skippy
When I was waiting to have my car annualy checked (MOT kinda) I left the engine running for several minutes. To my surprise the needle started creeping up after several minutes till halfway. I must admit that I had been horsing it just before but still it took at least 6 minutes for the gauge to stabilize. The car passed with flying colours, loud and low.
#42
Originally Posted by kris
...To my surprise the needle started creeping up after several minutes till halfway. ....it took at least 6 minutes for the gauge to stabilize...
#43
Originally Posted by springer3
Oil expands with rising temperature, and that is why the level gets higher when it is hot. ...
#44
Skippy
What is the mileage on the engine?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#45
The dipstick never lies BUT being sure of what it is telling you is something else!!
This device is responsible for so much over and under filling.
I will never forget the tracked 993 idling after a good blast and the owner telling me that the oil level was good on the dipstick even though the level gauge was pegged at the bottom. 3 litres of oil later the gauge was on half with the cooler fan cutting in and out !!!!!!!!!!!
If the gauge does nothing , ever, use the stick otherwise I am using the gauge.
All the best
Geoff
All the best
Geoff
