964 Forum 1989-1994
Random 964 Picture Thread
Old 01-21-2013, 05:27 AM
  #3421
Porsche964FP
Porsche964FP's Avatar
Originally Posted by g60pops
[IMG]
Old 01-21-2013, 07:47 AM
  #3422
Polman
Polman's Avatar
Ha,ha....just must fix a lot off thoose warning signs...and offer them here. Should be a standard sign in every Porsche
Old 01-21-2013, 12:21 PM
  #3423
Mr.Alex
Mr.Alex's Avatar
Provoste, can you post the specs and tire sizes of the wheels, and tire brand. You on coil overs?
Old 01-21-2013, 03:00 PM
  #3424
provoste
provoste's Avatar
Default 964 Kinesis
Originally Posted by provoste
Big black install pic and recently updated look with refurb'd Kinesis (Thanks Thatcher!)
Yes, it is on coilovers, Re-sprung (higher spring rates) PSS10's. The wheels are Kinesis K27's 8 x 17 front running 235/40 & 9.5 x 17 rear 275/40 Toyo R888
Old 01-21-2013, 03:06 PM
  #3425
geordie
geordie's Avatar
^ Interesting.
What are your revised PSS10 spring rates?
Old 01-21-2013, 03:28 PM
  #3426
provoste
provoste's Avatar
Originally Posted by geordie
^ Interesting.
Nothing crazy but significantly stiffer than stock PSS10- 8kg front ~450lb & 10kg rear ~560
Old 01-27-2013, 08:15 AM
  #3427
Pierre Martins
Pierre Martins's Avatar
Breakfast run this morning...
Old 01-27-2013, 01:11 PM
  #3428
Porsche964FP
That's a good chunk of sticky meat on them wheels.
Any clearance issues due to the wide rubber?
Is your car a C4?
Old 01-27-2013, 02:20 PM
  #3429
provoste
provoste's Avatar
Is your car a C4?
The fronts were no issue, the rears required a little rolling. It's a c2.
Old 01-27-2013, 02:26 PM
  #3430
Porsche964FP
Thanks - what offset are you running?
Any rubbing on the inside?
Old 01-27-2013, 02:47 PM
  #3431
provoste
provoste's Avatar
I bought the Kinesis off a fellow PCA'er who was running them on his 964 for track tires..not sure of offsets, I never measured and there are no markings (not surprising considering offsets can vary by barrel size). No rubbing on the inside (running coilovers). The offsets are much more aggressive than the OEM 7&9 Cup 1's which have street rubber on them.
Old 01-27-2013, 02:50 PM
  #3432
Porsche964FP
Thanks for the feedback
Old 02-07-2013, 05:49 PM
  #3433
DWS964
DWS964's Avatar
Default OMG, work just Sucked today...
Luckily this is what awaits me upon exiting the building.
Old 02-07-2013, 05:57 PM
  #3434
geordie
geordie's Avatar
Thank you!
Old 02-07-2013, 11:03 PM
  #3435
HiWind
HiWind's Avatar
Route map for this long weekend - doing 2/3rds of this - had to load the spare jic
Otherwise known as the road thru the mountains - 17 passes
Meeting 22 other p cars - vid loaded
Quick Reply: Random 964 Picture Thread
