Camera mount for a car without a roll bar
Has anyone ever figured out how to mount a video camera in a coupe without a roll bar? I would like to see just how bad I am at the track...
It shouldn't be that difficult to find a place that suts you. I've seen them mouned nearly everwhere.
Helmet, Dash, Wheelwell, Bumper, A-pillar, Rearveiw, and Sideveiw.
Howevr, if you are concerned about cosmetic damage you may want to buy a mount, or make one yourself and save a few bucks.
Duncan
Duncan
You could install a harness bar and put the camera on that. That places the camera behind your seat, so you capture a wider area. I don't like windshield mounts for that reason. Probably expensive just for a camera mount but it's an idea.
You could also buy a bullet camera and install that anywhere you want using a suction cup mount, such as on the hood, on top of the car, side, etc. Check out chasecam.com (no affiliation).
I bought a simple mini tripod for my Sony cam and set it on the folded down rear seat backs. Then cable-tie a bungee cord to the u/s of the tripod head and hook each end of the cord onto the rear seat belt centre mounts - stretch v tight - thread the cord down thru the gap between the seat backs. Sounds a little "unstylish" but if you get the bungee tight enough and the tripod legs as wide as possible (!) it works and there's no drilling involved. You can set the camera height using the tripod adjustments and the camera can face forward , back side or whatever you want.
Sorry no pics but next time I use it I'll snap a couple if anyone's interested.
Cheers
Cheers
Here you go - favoured supplier to many of the Gumball 3000 entrants
http://www.b-hague.co.uk/camera%20su...%20systems.htm
