engine warning light
hi,just got a phone call of me brother to say a light with wot to looks be 2 pulleys and a belt has just come on, am i right in thinking this is the engine warining light or if not wot is it,if so wot does this normally mean
thanks chayten
thanks chayten
Burgled
the warning light for the fan belt. May be just the sender that rest against the belt but check before driving or you can mess up the motor. Could be broken belt, loose belt or bad sender. Its on the top left side of the belt and is a little wheel.
