Replacing the windshield seal Qs
Jarhead
My seal is badly distorted from age and the ravages of Mother Earth and I'm thinking it's time to replace it. My windshield, however, is absolutely perfect. I also have no reason to believe that I have any rust to contend with, although I know there very well may be a bit hiding beneath the seal. I've done my search, and I still have a few questions... Does the windshield absolutely have to be replaced? What are the chances that it can be removed without breaking it? Any ideas of the price of a new windshield? Anybody have any experience with this issue?
Brian
Brian
no need to replace glass to change rubber. someone might tell you this to scam you of more cash. especially a windshield place. maybe if you are not doing it yourself find a place that restoes cars and they should have plenty of experience in doing this. make sure they work on porsche
Super Duper Moderator
Brian - I had a dime-sized spot of rust fixed by the front WS seal last year. A great bodyshop removed the windshield, fixed the rust, and replaced the WS without it getting broken (used a new seal to install) - so no, the WS does not have to be replaced.
Marc
p.s. YMMV as they are fragile at this age though.
Marc
Jarhead
Brian
Hiya bhensarl
If you cut away the rubber from the glass , the glass will be easy to remove . Don't cut the rubber away from the body . The lip of rubber that goes over the edge of the glass is what needs cutting away .
The tool I like is a carving blade "V" shaped .
http://www.dickblick.com/zz330/15/
Upper left corner .
Upper left corner .
Technical Guru
Originally Posted by garrett376
Anyone know how much a new windshield runs?
Originally Posted by bhensarl
... My windshield, however, is absolutely perfect. ...
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
