Exhaust leak sound
From: Prather, California: somewhere in the middle of the State
Exhaust leak sound
Wife's '91 C2 recently began to make a noise from left side of engine that sounds like an exhaust leak. It reminds me of the old days when the muffler would rust out. A visual exam with engine off did not reveal any holes in the system. When at idle I cannot locate the source of the noise, but can definately hear the sound.
Before I start tearing anything apart, does anyone have any experience of similar "leaks" and is there a way to locate the source of the leak?
Hiya Jerry Garwick
Do you have a stethoscope ?
http://www.chain-auto-tools.com/engi...ls/AMR199L.htm
http://www.toolshoplist.com/product_...roducts_id/550
If you don't , a hose in the ear test will do .
Professor of Pending Projects
The gaskets in our car's exhaust system are big metal pieces. Only the Cat has a "normal" flat metal gasket. With time/rust/etc sometimes the clamp, or gasket break. Follow Indycam recomendation to narrow down where the leak is...
Here is the follow up on the exhaust leak. After removing the heat shields around the cat I could feel the exhaust leak around the flange and tube of the front end of the cat. When I removed the cat I found that the tube part of the cat completely disconnected from the flange. I welded it back in place and after much cursing and breaking several bolts, managed to get the flanges to seal. Problem solved. But I was very surprised to find the flange disconnected in the first place. This would have an expensive problem if I had taken it to a Porsche shop. I think they would have sold me a new cat.
