Ticking noise from distributor?
I have a ticking noise coming from the distributor area. Have changed both distributor caps & rotors & both leads from distributors to coils. Next step is the spark plug leads. Any one else come across this?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Still check the belt. They have been known to slip off.
I would also remove the caps and check the rotor is not impacting anywhere on the inside of the cap. Maybe a small amount of lube would not go astray on the centrifugal weights assembly at the bottom of the assembly.
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
