This is odd... I can't explain it.
Professor of Pending Projects
Originally Posted by Jeremy Pinsly
Just to keep people level-headed here........don't let this thread turn into a "993-type" word war.
We are known to be a friendly and helpful group of enthusiasts.....Let's keep it that way!!!
Rob, I suggest you remove you phone number from the post. You can always (and it is best) send a PM with that type of info.
Now peace brothers in oil!!
Gentlemen - as Jeremy has already pointed out, let's keep it civil, please.
While we are all permitted to express our own opinions and disagree (if we all agreed, this would be a very boring place), we should try to remember that we are all friends here and act that way.
Marc
Marc
[QUOTE=Marc Shaw]While we are all permitted to express our own opinions and disagree (if we all agreed, this would be a very boring place), we should try to remember that we are all friends here and act that way.[QUOTE]
Peace
Peace
closing out the thread
Close-out message & follow up.
Update 1 - my engine has resumed it's normal drips. I can't explain why it ceased for a couple days, but it has resumed albeit with a slightly lesser volume. Perhaps going up and down on the lift a few times jiggled some connection somewhere, before driving jiggled it back. (week I know...)
Update 2 - the oil-level odd behavior isn't there anymore. I'm going to chalk this up to operator (me) error in just looking at the indicator when all required conditions were probably not met. At temp, on level ground, at idle; I am 1/4" below the full notch on the dipstick and showing just below the fat full mark on the guage.
So outside of a quieter operating engine pertty much everything else has returned to normal. The extra torque feel, I think is there but it's been cooler here in Chitown since I started the post, and I also have much less petrol in the car. Weight reduction of (10gals x 6lbs/gal) 60lbs might explain it, odds are however much better it's my imagination.
In the end I'd say don't oil a snake, but my old well-worn engine likes this particular snake-oil...
Did I mention that this stuff made me appealing to swim-suit models and allowed me to win the lottery as well...
"Did I mention that this stuff made me appealing to swim-suit models and allowed me to win the lottery as well..."
I'll be running down to the auto parts store now to see if I can find some .
Marc
Burgled
Oh, I'd believe that - I took my engine undertray off 'cause I was told it made me look 20 lbs lighter, 10 years younger, gave me minty fresh breath and the car an extra 50 hp.
I have a TIP so being a slower less worthy car it only gave me 40 HP more
I remember my Uncle telling me that he bought some spark plugs that increased the fuel mileage 25%. Then he bought some fuel additive that increased the mileage 30%. Then he bought a special carburretor that increased the mileage 50%. He then drove 4 blocks and the gas tank overflowed. I think there was a message in that story.
Rallydog,
If you like it, then it works for you. But...
Porsches are like older Harley's in that they like to mark their spot. That way they know they're home. I've had several of each and except for my 964 they all had a drip complex.
Sure you're gauge read full, that's why there is a dipstick. I rarely pay attention to the indash indicator.
I just stopped by my wrench to have my airbag/seatbelt lights reset (my own fault this time) and he told me that my car needed the valves adjusted again because they're chatteirng. They were done a little over a year ago, so go figure.
Happy motoring!
Happy motoring!
The techs I have talked to over the years swear by BG MOA for use in dino oils. They also swear by 44K. I've used 44K for years. Since I always run synthetic oils, I have no need for the MOA and have no personal experience with it... But I have seen what 44K can do for a car or truck in need. IMHO... It's good stuff!
I have a 91 3.6 litre in my 1977 911 wide body. I switched from 20w50 dino oil to Mobil 1 0w-40 a few months ago and the few minor oil leaks that the engine had are gone. Totally dry garage floor. I guess the seals like this Mobil 1 formula. I always thought going to synthetic made leaks worse but not in this case.
Also before I put the 3.6 in the car I had a very worn out 3.2. Bad compression and leakdown on one cylinder bank. Before taking it to track events I would add a can of Automotive Products "Restore". Car would get back its missing torque and performed very well for the track event. Then after a few hundred street miles it would go back to its tired state.
