When do the original struts/springs wear out?
I know this may be a dumb question, but at 104K miles and a new owner, I'm wondering how shot my struts could potentially be. Not having ever driven a p-car before, I don't really know if mine are "squishy" - it honestly seems a little bit more squishy than I expected. So I'm wondering if going in with "fresh" stock parts I could expect a somewhat stiffer/more responsive ride. Normally I'd tell myself yes, but I don't know, are Porsche OEM struts "magic" and if I want something stiffer I'll need to get stiffer-rated stuff?
IHI KING!
I replaced my original springs and shocks at 140K miles. The shocks were worn and causing uneven tire wear. I took the opportunity to install H&R lowering springs and Bilstein shocks. Afterwards, I was amazed at how much better the car felt at speed and felt that I should have replaced the shocks sooner.
My advice is to drive another 964 to compare and then decide if its time to replace or not.
I replaced mine at 30k miles after 10 years and they were one step from shot. The Bilstein H&R combo was worth every penny although a bit weak for track use. They can be adjusted from stock height to lower than euro height. I am running at euro height and it makes for superior ride and handling. Probably the best improvement I could think of.
Super Duper Moderator
Originally Posted by cobalt
I....The Bilstein H&R combo was worth every penny although a bit weak for track use.....
I am thinking of suspension options as a winter project and I'm starting to research this now.
Thanks.......Marc
Originally Posted by Marc Shaw
Why do you say that? What makes them weak - too soft?
Thanks.......Marc
Thanks.......Marc
