Drilled it, now wish I hadn't!! - ALMOST CURED
OK, so I bought that airbox cover off Ebay, Drilled it just like John Miles says. Got in it today for a first Burn, shoulda seen the smile on my face at 4000 revs and a cherry bomb noise! However, the car has suddenly gone jerky - coincidence or do I have to DME reset?
Also the wife called me a chav because of the noise!
May have to revert to old box and ebay the drilled one!
Advice welcome on jerking problem!
Professor of Pending Projects
Originally Posted by robmug
Coincidence I'd have thought. Mine didn't go jerky when drilled.
I'd definitely try a DME reset.
what are the symptoms of a DME relay going bad? Is it a "it works or not" type thing, or does it sporatically cut out the motor giving a jerkyness like brooke describes (or a different kind of sputter/jerkey action)?
I have drilled a lot of air boxes in my day and never had trouble, but I do remember reading on some sites that a rough idle and stumbling can result. I have no idea how. I have run mine with no lid, filter or anything at a auto cross and did not have issues.
On both my 964's I've modded the Air Box cover - on the 1st, I drilled it like John Miles & didn't like the resonance it caused. On the second, like you I bought a spare cover & cut a large square hole in it, just like the cup/fabspeed cover & it sounds great! No resonance! Never had any idle/hesitation side effects from the engine.
I'll pop the old one back on tonight and reset the DME, then report back.
A chav is a word over here which describes your typical hoodlum in a cheap car with a large exhaust pipe, under car neons and a burberry cap.
Originally Posted by Chris M.
Mine worked fine after cutting a portion of the airbox cover away.
What's a chav?
c
What's a chav?
c
Chavs don't drive Porsches. They prefer 'souped up' shopping trolleys ( e.g. Citroen Saxo, Renault Clio, Vauxhall Corsa)
