964 Forum 1989-1994
lowering a 964
Old May 5, 2002 | 10:00 PM
roadster's Avatar
roadster
Question lowering a 964
I'm looking for advice on how to eliminate the enormous fender wheel gap (3"-4") on my 92 Roadster.
I was once told that you can adjust the ride height without shelling out additional $$ for new springs. Is this true?
I have the 92' Turbo suspension, as oppossed to the standard 964-for whatever that's worth??
Any advice is greatly appreciated.
Old May 5, 2002 | 10:51 PM
Kevin's Avatar
Kevin
Post
I have used Doptke spring perches with good success. They allow you to use your stock turbo springs.
Old May 6, 2002 | 12:48 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
"SEARCH" the various posts would be my advice...there's a lot of information on here regarding lowering a 964, that's for sure!
Also, check out my lowering/suspension upgrade article on <a href="http://www.porsche964.co.uk" target="_blank">www.porsche964.co.uk</a>
If you aren't educated on suspension upgrades/options/ideas by the time you've gone with those two suggestions...you need help!
Old May 6, 2002 | 05:48 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Dear Roadster,
The ride height on standard 964 supsension and the 1992 964 Turbo is the same. The springs are 40% stiffer and the rears are progressive. The 1991 964 Turbo had the same springs as the C2. Blue coded ones if I remember correctly.
You have an effective 10mm lowering using the installed spring perches.I do not believe the Dopke Spring Perches are available anymore. I have not heard from Clay in some time.
The most effective way to lower is to purchase a new set of springs. Which ones will be determined by your driving requirements. Generally I do not just recommend replacing the springs because you can cause your shocks to bottom out. Anyway, Jeff suggests a check of the archives. This is a good idea because this subject has been discussed many times. In the end though any modification needs to suit your driving habits and requirements,
Ciao,
Adrian
911C4
