How to remove the AC Compressor Clutch?
So, the AC belt was left a little loose after replacing the ignition wires, and after an autox, the belt slipped off, and took the clutch control wires with it..... any hints on how to remove the clutch assembly? There is the 10mm bolt in the center, but how to you keep everything from spinning? Thanks for any advice.
