ABS Indicator Light On
So, if I hit a nasty bump (which occurs too often on these lousy roads), the ABS Indicator Light comes on briefly. Any ideas as to where I should start looking? I'm guessing that one of the wheel sensors has a less than ideal connection. What do you folks think?
Cheers,
Mark
Cheers,
Mark
Interesting. Is this the indicator light on the lower center console where you are able to switch into 4-wheel low? I have that little yellow light flash when I hit bumps on the highway. I've only noticed it at night, but I expect it happens in daylight as well, but I've just not noticed it.
Mark, I have a 1990 C2 with the exact same problem. After checking all the basic connections I decided to let the Porsche dealership give it a go. After several hours of diagnostics (a.k.a.$$$$) they told me it was a faulty brain. I find it hard to believe because the system acts normal (pulses brakes when wet ect..) however once a decent bump is hit the abs and the warning lights illuminate and the buzzer goes off. I did not have the $1300 brain replaced, just a bit too much money for me right now, also I figure I will eventually find the true fault. Let me know if you find anything out. Thanks, Steve
It is common for the ground connection near the ABS valve block to be corroded - several times people have posted this intermittent problem, and solved it by unscrewing, cleaning, and reinstalling the various ground points in the front hood (there are three, I think). From memory reading those posts, it seems the ground closest to the ABS valve block (behind the battery) is the culprit.
C4 guys - if you want to see your PDAS functioning more easily, install the green PDAS bulb in your combination instrument...
https://rennlist.com/forums/964-forum/106325-green-pdas-activation-light-in-dash-gauge-how-activate.html
Great advice, I will check those grounds and fluid level tomorrow. Mark964 there is also a ground that can be cleaned above the abs brain under the carpet, in the front hood right side of car.
Check also to see if your speedometer is working. I had a situation where the ABS light was on and the speedometer was not working. The problem was a relay in the main fuse box location above the fuel tank. I forget the name of the rely but I think you can look in Adrian's book and find it.
Jerry
Jerry
OK, so I diagnosed and fixed the problem. Turned out to be a bad connection on the under side of the central fuse/relay panel up front. Took a while to figure out, but I did. So, thanks again to all who responded to my plea.
Mark
Mark
