Help leak over accelerator pedal (Left hand drive) - Pictures
I have noticed a water (?) leak when I was turning a corner today. It actually happened twice. I did notice both times I heard something turn on behind the guages then the water came down.
...any clue?
View from below
Leaking water???
Another view from below
Thanks,
Puma
...any clue?
View from below
Leaking water???
Thanks,
Puma
Originally Posted by jimq
clean airconditioner or air intake on hood drain tubes that come out under the car.
thanks,
Puma
Burgled
It may have been just sitting in there then sloshed out as you went around the corner, started moving etc. Happens on any type of car not just ours.
Then again maybe your heater core is leaking coolant
Super Duper Moderator
Marc
IHI KING!
My car had water come out of the same spot just recently. The fix was the clear the drain tubes. I know your car's problem isn't when its raining but I still think the same fix is relavent. The 964 has two drain tubes. One for rain water and the other for water from the air conditioner condensor. There is a vent that is centered in the car above the tunnel. Its hard to see but that is where the water was coming in my footwell.
I suggest trying to clear your drain tubes. It only takes a few minutes. Just jack up the right front and poke a wooden stick (1/4" dowel) into the two drain tubes. See the photo posted by JasonAndreas on this thread. The tubes are in the opening of the black cover plate. https://rennlist.com/forums/964-forum/212933-water-pours-on-my-feet-out-of-lower-heater-vent.html
If that isn't your problem, then it hasn't cost you much. Let us know what you find.
I suggest trying to clear your drain tubes. It only takes a few minutes. Just jack up the right front and poke a wooden stick (1/4" dowel) into the two drain tubes. See the photo posted by JasonAndreas on this thread. The tubes are in the opening of the black cover plate. https://rennlist.com/forums/showthread.php?t=212933
If it's not raining, then the water has to come from your a/c, or we're barking up the wrong tree. If you don't use the a/c, do you still get water? And yes, there's a lot of water from the a/c system, you should see it under the car on a humid day after running with the a/c on. It'll even drip off the hoses under the sills, condensed from the outside air.
If you're sure it's water, and it's not raining, my money's on a clogged a/c drain.
IHI KING!
Puma,
That is the exact same place my car had water coming in. If you feel around, you will find there is an opening in the bulkhead where the heater ducting enters the car. I had water sloshing into the footwell. The side that got wet depended on if I was turning left or right. I am still convinced that clearing the drain tubes will resolve your problem. I will see if I can post a diagram of the heater drains so you can better visualize it.
Update - Got the diagram posted. The two tubes to clear are #11 & #12.
I have the same problem. Checked and cleaned the drain tube. No problem there. I still get water on my feet on the passenger side.
I wish there is a way to take the system apart to clean them.
Puma,
Also noticed a little water spitting from the center vent. (very little barely noticable)
Oh yeah THANKS for the picture
I wish there is a way to take the system apart to clean them..
