Bad Fuse Connections
Here is something I thought I would share. I had a problem about a month ago where the AC on my 90 C2 would not cool properly. When I checked the high side pressure, I found it would go upto about 400 lbs. Found that the condensor fan was not coming on causing high temps on the pressure side. This was caused by bad connection on fuse #39 in the central electric box. I put a slight twist on the fuse prongs, and havent had a problem since.
Then a few days ago, my interior ventilation fans would go in and out which seemed to be caused by bumps in the road. Further investigation found I had a similar problem with fuse #1. I put a slight twist on this fuse and resolved the problem.
Has anyone else experienced this type of problem? I suspect the only true fix is to replace the whole fuse box, but that is probably quite expensive, especially if my twisted fuses will suffice.
Thanks for sharing this with us. The current owner of teh 964 I am negotiating told me he had done the same thing with some fuses. The heat and humidity here in Panama plays havoc with any electrical component
He has a special grease (I will try to get the name of it) that protects against humidity and corrosion, while at the same time conduct electricity
Location: Seattle - it's not Hell, but you can see it from here!
it's called Dielectric Grease and while it does protect against humidity and corrosion, it is non-conductive. the metal parts of the connector still have to make contact.
you can use it to pack under-hood connectors to keep water out and not get shorts between pins.
