Oil level 964
7th Gear
Oil level 964
I recently purchased a '91 C2. I have a question about checking and adding oil. The car is driven everyday approximately 10 mi. Should I check the oil level when the engine is hot or cold? How much oil should I need to replace between oil changes? Also, I heard not to fill to the top because it will overflow afterwards. Is this true, and whyso?
Hi,
Oil level should be checked when the car is at normal operating temperature (i.e. hot). Also, it should be checked while the car is idling, and while it is on level ground. If you have a handbook with the car, I think that gives details. Don't check the oil with the engine switched off.
Not sure how much you should replace between oil changes - just keep an eye on the level and top up as necessary.
I have been told that it shouldn't be filled to the top - I guess because the oil expands as it heats up. If you fill it right to the max mark, then if the car gets very warm the oil may expand enough to overflow.
Dave
90 C4
Dave
90 C4
I agree with Dave re checking oil level. One problem I have is that the oil level is often hard to read on the dipstick. Under those same conditions that you would check oil level on the dipstick, your oil level gauge on the dash should also be reading correctly.
That's about the only time it reads correctly, however.
On refill after draining, you will need about 2 quarts less than total capacity indicated in owner's manual in order to get the level about half way between the upper and lower marks on the dipstick. Thus, about 9 quarts should do it. No need to ever get it above half way. It's ok to wait until the level drops to 1/3 or 1/4 the way between the two marks before adding 1/2 qt and checking level. Overfilling is easy to do.
Hi-
10 miles may not be quite enough to get up to proper operating temperature. My policy is that is the oil temp gauge must be at the second line (about 8 o'clock as I recall, which is actually the third line if you count the very first one at the bottom). On a completely level surface and after at least 30 seconds of idle, you should be able to get an accurate reading with the engine running. It should be above the red, but not hitting the top mark for safety's sake. I add very small amounts like about a 1/4 quart and keep my eye on the gauge through the rear window, pausing for about 1-2 minutes during each addition for the gauge to register and to check the dip stick. I stop when the gauge reads 3 o'clock, with the stick corroborating. Always verify with both the stick and the gauge- using just one of the measurements will lead to an overfll IMO.
I would also consider taking the "long way" to work. Assuming 5 miles each way for your 10-mile daily drive, is not a good practice for maintaining overall health of the car.
Jon is correct... make sure the operating temp is reached before adding any oil. I also like to see the level about 2/3 of full on the dip-stick and/or guage... I am currently wiping the inside surfaces of my entire intake system because the previous owner had the level maxed out.
7th Gear
Thanks for the additional input. My trip to and from the office is 5mi. each way. I am a pretty aggressive driver. I have had the car for one month, but I am gaining more confidence behind the wheel everyday (especially after reading driving tips from different users on the forum). I make it a point not to "baby" the vehicle. Do you recommend that I really unwind it once or twice every weekend. If so, under what conditions?
Also, you will all be sorry to hear that I was rear-ended by someone after owning the car for only two weeks!
Monte
Monte
Re: aggressive driving / unwinding -
Check your manual, - if you have it. I believe that mine states that the engine should not be driven above 4500 rpm until it has warmed up...
Congrats on the new car!!
Jack http://people.ne.mediaone.net/jbalthasar
lehmkuhler
Go for it!!!!
we have major problems here in the UK with 911's which have lived all their life in central London and have never been opened up properly, top end overhaul at 40,000 miles is not un-common!!!
Always warm the car up thoroughly, and once warm, drive it by the scruff of it's neck, it will do the engine the world of good!!!
Good luck!!!!
Go for it!!!!
Good luck!!!!
